My first retro build : 2005's finest (almost)
First post, by acl
I've been hanging around for some time now, but i've never presented the systems i'm using.
There will probably be a topic for each one (if i have time) and i will start with one of the first i built.
Current configuration :
(history and parts evolution below in the second section)
I tried my best to get really close to the top gaming configuration possible in 2005.
The attachment IMG_20230226_215026red.jpg is no longer available
  • Socket 939 Asus A8N32-SLI (updated from A8N-SLI Premium in 2025)
  • AMD Opteron 154 (~idem Fx-57) : 1c/1t 2800Mhz 1MB L2 cache (locked mult)
  • 1GB (512 x 2) Adata Vitesta DDR500
  • 2x nVidia GeForce 7800GTX 512MB in SLI
  • Creative Sound Blaster X-Fi Platinum PCI (with front 5.25 bay panel) -> Temporarily replaced by a (non period correct) X-Fi Titanium Fatal1ty PCIe 1x (for cooling reasons)
  • Western Digital Raptor RAID0 2x 36GB SATA
  • Windows XP
  • RaidMax Smilodon Case
  • Custom cooler (air)
The attachment IMG_20230225_225153.jpg is no longer available
The attachment IMG_20230226_215035.jpg is no longer available
The attachment IMG_20230226_215044.jpg is no longer available
The attachment IMG_20230226_215055.jpg is no longer available
There still some room for improvements :
  • Memory : better timings are possible
  • Motherboard : A8N32-SLI is a 2005 board with dual 16x PCIe instead of dual 8x
  • Storage : 74GB Raptor are slightly faster than 36GB. I would love to add an I-RAM ... but super hard to find.
  • Ageia PhysX ?
History and parts evolution :
I've always been nostalgic about 2005. Some may not consider this retro at all, but for me it's special.
It's not the year i got into computers, it's not the year i owned my first personal PC. It's just a year i had a lot of fun with friends and PC gaming in general.
During early 2000's, i had a nice little retro collection, mostly early/mid 90's and some 80's computers (not only PCs). A lot of CPUs and some video cards... but i had to trash most of it when i moved to my own place as a student.
I slowly restarted collecting stuff in the 2010's. I already knew i wanted a 2005 dream machine and i started around 2017/2018 to collect parts for this project.
What i initially had in mind :
  • Athlon64 based. The fastest FX57 if possible
  • nVidia SLI. (I'm a big ATI fan, but nVidia was faster in 2005)
  • Stupidly exotic storage (Like WD Raptor Raid or I-Ram)
  • Good sound card
And the journey was not as calm as i expected.
I first had trouble with my first motherboard. A K8N SLI if i remember correctly. The problem is that i only had one socket 939 CPU, one socket 939 board and only on DDR kit.
Sure, i had some 486 and Socket7 parts, SDRAM etc... But no 2005 spare parts around, so i was unable to tell which part among CPU, MB or RAM was faulty.
When you're re-starting an hardware collection (or any hobby that requires testing and tinkering), there is a minimal "critical mass" of stuff you need to have, just to be able to test. Don't underestimate that like i was.
To troubleshoot, i had to buy a fully tested complete system with motherboard CPU ram and cooler (for ~45€)
The issue was the first motherboard (And the return delay was expired by a large margin so i lost 40€ on it... awesome !)
I bought the Opteron for 40€, a pair of GTX7800 256MB for 100€ the lot and a Sound Blaster X-Fi for 20 something €.
I added the Corsair XMS kit i already had since 2005, a pair of Raptor i got for free and a case i had in my garage.
Let's call this the "Version 1.0 Release Candidate"
  • Socket 939 Asus A8N SLI Deluxe
  • AMD Opteron 180 (2c/2t 2.4Ghz)
  • 2048 MB DDR400 (4x 512 Corsair XMS 2.5/3/3/6)
  • GeForce 7800 GTX 256MB SLI
  • Windows XP
  • Custom case
This was quite close to what i initially wanted, but with some drawbacks.
  • Opteron 180 is a great dual core late 2005 CPU. But most of period correct games can't handle 2 cores
  • 7800 GTX 256 MB was not the fastest version. There was a 512MB version with significantly higher frequencies (but quite rare).
  • Memory could be improved (in quality) and 2048 is not strictly needed for 2005.
The system worked, but i had frustrating stability issues with the system. And sometimes, overheating issues with the two 7800 GTX.
I thought the two could be related.
When i received the two 7800GTX, i cleaned them very thoroughly and replaced the thermal paste and pads. When i disassembled the two GPUs to find what caused the overheating, i almost immediately found the cause.
The pads were too thick and the cooler was not making good contact with the GPU.
Well done ! I could have toasted my cards !
I know it's not recommended, but i added a pad on the GPU to fill the gap as a temporary solution. I first thought that the pad will not conduct enough heat, but this was not that bad. Definitively better than before.
But the stability issue was still there. So probably not caused by the overheating.
I stopped troubleshooting for a while and used the system for games. But it was very frustrating to use. Crashes were totally random. And i found no link between temperature and crashes.
So i just used the system like that for some time.
A few month later, i finally found a 512 7800GTX !... but only one. I got it for very cheap, something like 20€ and it worked perfectly.
I "just" needed to find a second one.
Somewhere around may 2022, my Opteron 180 died (just after using it my GPUJune video)
I was using it in another motherboard for a test. Everything worked well. But no boot after re-installing it in the 2005 system.
I installed it back in the system i tested just before. Same issue, no boot.
I suspect my cooler to have damaged it since the mounting was (by design) super tight, and i had to use quite some force to attach the clips.
I replaced the cooler with a stock one and used a Athlon64 3500+ i had instead.
We're not getting closer to the ultimate 2005 system by downgrading the CPU !
I could have replaced the CPU with the same one, but i was thinking about using a higher clocked single core instead.
Of course, Athlon64 FX57 are not easy to find, and not cheap either. But i finally found an alternative : Opteron 154.
It's quite exactly the same CPU, only with a locked mult : 1c/1t 2.8Ghz 1MB cache socket 939.
I found one for around 80€, not cheap, but a lot cheaper than an Fx57.
Now, we're getting closer !
Then, in late 2022, i finally found some 7800GTX 512 for sale. From a recycling company selling mislabeled 7800 GTX 512MB for less than 15€... but untested... and with expensive shipping.
I gave it a try and ordered two. I received the cards about three weeks later (yes, that's not Amazon prime next day delivery)
Among the two i received, one worked perfectly, and with the one i already had waiting, then i finally had my SLI !
I replaced the two 256MB cards with the two 512MB started the system and launched F.E.A.R.
Everything worked perfectly.... silky smooth.... for about one hour.
Then windows crashed. And after rebooting, the card has disappeared from the Device manager.
Not the one i just received untested. No ! The one i kept waiting for more than a full year.
Dead. Just like that.
I was so disappointed that i stopped any retro activities for a month or so.
Then i ordered, again some untested 7800GTX 512MB from the same recycler and finally; 3 weeks and 70€ of shipping and taxes after, i was able to have a working SLI.
But i still had this stability issue. Still unresolved from day 1.
After dozens of experiments, (including buying new RAM, a new motherboard and a new PSU) i finally fixed the instability.
I tried :
  • Different memory brands (Corsair, Kingmax, generic)
  • Three different motherboards with the same Nforce4 SLI chipset
  • Three different CPU (3500+, 4000+ and Opteron 154) + the Opteron 180 before
  • Two different PSU (modern ones)
  • A lot of GPUs
It was apparently caused by the 4 memory sticks in dual channel.
For an unknown reason, everything works well with two sticks, while it randomly crashes with 4 on all the combinations i tested.
During this troubleshooting process, i bought a slightly different motherboard (A8N-SLI Premium), better memory (Adata Vitesta DDR500) and a brand new PSU. So this was the final upgrade.
The system now works perfectly, without any crash.
Update May 2025
I swapped the motherboard for an A8N32-SLI and this caused some choices to be re-evaluated. See here : Re: My first retro build : 2005's finest (almost)
Reply 1 of 25, by acl
+ Adding some screenshots
The attachment Config.jpg is no longer available
(Yes, i know i'm using the DDR500 at DDR400 frequency but i don't really want to overclock. Performance is still very good and now i finally have a stable gaming machine, i don't want to ruin that 😁)
The attachment 3DMark.jpg is no longer available
Reply 2 of 25, by 2Mourty
I'm a sucker for any sli system. Nice work!
Reply 3 of 25, by Irinikus
A very nice build with an interesting story!
Very nice work! 😀
YouTube
Reply 4 of 25, by kolderman
That's a lot of 7800s.
Reply 5 of 25, by psychofox
Great build! i am doing right now too an 939 2005 build. I am surprised how hard is to get quality parts for such system these days. Of course average parts for this period are literally thrown away, but i cant find quality DDR 1 memory for example.
Reply 6 of 25, by chinny22
2Mourty wrote on 2023-04-04, 00:52:
Same!
I've a pair of EVGA GeForce 7950 GT2's Cost me $50 each and came from Israel I think? This is back in 2018.
Problem is they hold back a XP build so I'm not currently using them but do want to build a rig around these at some point as well as an apposing Crossfire build.
Reply 7 of 25, by PcBytes
I kinda did a "2005" build too 😁.
The only things that are not fully period correct on mine would be:
-PSU being a 2012 Raidmax 700W unit (Andyson OEM)
-8800GTX from 2007
-4GB of DDR400
Wish I had enough power in there to power another 8800, and another 8800GTX for that matter - I'd be doing a SLi 8800GTX too. (R.I.P thermals tho)
As for finding parts - I can also agree how hard it is to find parts. Particularily, the x2 4600+ I was able to get for mine was pretty hard to find - the reason being most common 64 x2s here are AM2 Windsor/Brisbane chips with similar speeds.
Reply 8 of 25, by acl
psychofox wrote on 2023-04-04, 08:32:
Yes, Anandtech and other serious benchmark sites used crazy memory back then. Like some OCZ DDR PC3500 with super low 2.2.2.7 timings.
I've never seen these memory kits for sale !
DDR1 kits faster than 400 / pc3200 are quite hard to find (and they often have bad timings)
I only have two such kits. The Adata DDR500 and a 4 x 256 KingMax DDR433 / PC3500
But the more common Corsair XMS are easy to find, affordable and performs well too. The kit i bought in 2005 can reach around DDR450 speed.
Irinikus wrote on 2023-04-04, 04:04:
Very nice work! 😀
Thank you very much !
kolderman wrote on 2023-04-04, 07:05:
Yes, a total of 9.
Two "regular" 256MB
Seven 512MB... but 3 dead, one unstable in SLI and 3 in good shape.
The attachment IMG_20230225_000351.jpg is no longer available
The attachment IMG_20210825_225146.jpg is no longer available
The attachment IMG_20230104_182856.jpg is no longer available
PcBytes wrote on 2023-04-04, 11:30:
I kinda did a "2005" build too :D. […]
-8800GTX from 2007
-4GB of DDR400
You're right, high end dual core s939 CPUs can be hard to find. I was lucky with the Opteron 180, but every other i've seen were at least twice the price.
I hope my 180 is in a better world now. The CPU heaven 😁
I read your post too. Nice system ! 8800GTX were beasts.
I had a 9800GT which is a die shrink of a 8800GT iirc. A fanless one.
I used it until 2015 ! (replaced by a GTX960) Worked great for Diablo 3.
I have a 8800 Ultra.... but a dead 8800 Ultra :'(
Instead for my 2007 build, i'm using a pair of Radeon HD 3870X2 in Crossfire (Quad GPU !)
Great on paper, looks awesome, but disappointing performances (I may also present this build some day if i have time)
chinny22 wrote on 2023-04-04, 11:26:
Same! I've a pair of EVGA GeForce 7950 GT2's Cost me $50 each and came from Israel I think? This is back in 2018. Problem is the […]
Same!
I never heard of GT2. Or is that GX2 ? (The dual GPU dual PCB cards)
Reply 9 of 25, by Brawndo
Same!
I'm actually doing just that right now for a 2006 mid-range XP build. In the past week I've picked up two EVGA 7950 GTs, for about $50 for both shipped (couldn't believe they were that cheap) and I'm doing an SLI build on an Intel 975X board with a Core2 Extreme QX6700. I'm just waiting on the Creative Soundblaster X-Fi Elite Pro I ordered to arrive, then I'll have all the components.
Reply 10 of 25, by chinny22
acl wrote on 2023-04-04, 21:55:
Yes my bad GX2. Quad SLI 😀 very sexy but also very useless 🤣
Reply 11 of 25, by vstrakh
That Smilodon should have a side bar, hosting additional fan and pushing the cards into motherboard with adjustable pins/fingers/plungers (can't figure the right name).
Is it missing, or dropped entirely because of high cards? 😀
Reply 12 of 25, by acl
vstrakh wrote on 2023-04-05, 13:29:
Yes, you're right !
I have the bar, but i'm not using it. (It's very thick and i don't really like how it looks)
I added a fan in the floppy bay to blow on the upper GPUs (and the front case fan blows on the lower GPU through the disk bay)
I had to tune a bit the airflow when i changed the 7800GTX versions.
The 256MB version sends hot air toward the middle of the case, while the 512MB version sends hot air in both directions (in and out)
chinny22 wrote on 2023-04-05, 09:06:
Wow ! This must look crazy (the four PCBs seen from the top). But yes, i believe that performances must not scale with the number of GPUs. (When i tested my two 3870 x2 in crossfire, it was not the case)
Reply 13 of 25, by acl
An update to this build.
I finally swapped the mainboard for an A8N32-SLI.
There are some pros and some cons.
The attachment A8NSLI-premium.jpg is no longer available
The attachment A8N32-SLI.jpg is no longer available
For the pros :
  • The overall layout is a bit better on the A8N32-SLI.
  • The two PCIe 16x are shifted one PCI slot to the left. In my case this allow the two 7800GTX 512 to be in front of a fan blowing fresh air from the front of the case to the back. But this forced me to put the HDDs in the 3.5 inch rack above.
  • The "EZ-plug" (molex) that is used to add extra power to the PCIe GPUs (not mandatory but i use it just in case) is now near the ATX power connector (and not in the middle of the board)
  • The SATA connectors are more spaced. Allowing me to use 90° angled connectors
  • 8-phase power should help with OC
For the cons :
  • You can't use any PCI slot if you have two PCIe GPU in SLI with two slots coolers. Only one PCI slot is available and it blocks the top GPU airflow, at least for the 7800/7900 range cards who have the fan on the front side of the card. This sucks a lot. I tried to place my SoundBlaster X-Fi here but then there was a 15C° temperature difference between the two PCIe cards.
  • Performance gain... not spectacular in my tests at stock clock speeds.
  • I had to re-install windows because the previous install could not boot with the new board.
The attachment IMG_20250515_165443.jpg is no longer available
To address this heating issue i tried to place a fan above the GPUs, this was efficient but noisy.
As a temporary fix i removed the SoundBlaster X-Fi platinum (PCI) and replaced it by an X-Fi Titanium Fatal1ty (PCIe 1x) since the PCIe 1x slot is not blocking the airflow. This is defeating the period correctness but i really don't want the top GPU to overheat and that sound card is still an X-Fi card with the same feature set. I still can revert this and use the PCI card + the noisy cooler if i want to be "2005 only".
Another solution would be watercooling the GPUs.
I had other issues while swapping the mainboard... like breaking the sata connector of a raptor hard-drive. I fixed that my swapping the HDD board with and identical one i had around.
Reply 14 of 25, by RetroPCCupboard
Very nice build. I have plans to do similar. It will have dual GTX 7900 in SLI (From 2006) and Core 2 Duo E8600 (From. 2008). I am calling it my "Ultimate DirectX 9.0 build". I have a couple of 300Gb Velociraptor drives that I may use.
Reply 15 of 25, by acl
RetroPCCupboard wrote on 2025-05-20, 12:15:
Great! I have plans for a C2D build too. I never had one back in the days (I had an A64 then a Phenom 🤮) I'll do it if i find a working 2nd 8800gtx.
What motherboard do you plan to use for this build ?
Reply 16 of 25, by RetroPCCupboard
acl wrote on 2025-05-21, 05:46:
I have an nVidia 780i chipset motherboard. I forget the brand. I don't have access to it right now.
I am planning an ultimate DirectX 10 build also. With Intel i7 3770 and two Geforce 285 in SLI.
Reply 17 of 25, by acl
RetroPCCupboard wrote on 2025-05-21, 07:51:
Yes nvidia chipsets were the only ones to support SLI in this era. This changed later with Intel X58 for first gen core i7. It supported both SLI and Crossfire while being a "non nvidia" chipset.
Reply 18 of 25, by MrSegfault
Eyy. I have that same case as you.
CB626E5291B62A15D215C0284FD225FE95AD863C
CPU: Intel Core 2 Duo E7500 2.93 GHz Dual-Core
Graphics: EVGA NVIDI​A GeForce ​7900 GT 25​6MB + Zalman VF9​00-Cu Cooler
Memory: 2 GB (1 x 2 GB) DDR2 Memory
Soundcard: Creative S​oundblaste​r Audigy 2​ ZS
Storage: 1TB + 500GB SSD + 120gb HDD
Reply 19 of 25, by acl
MrSegfault wrote on 2025-08-07, 02:33:
Eyy. I have that same case as you. https://images.steamusercontent.com/ugc/17936884313144568797/CB626E5291B62A15D215C0284FD225FE […]
Oh nice. And we both have Mr Clean as profile picture 😄
