First post, by mwdmeyer
 - Oldbie
Hi Guys,
I've got a nice little Pentium 200 MMX machine I use for a lot of retro gaming. Specs:
430TX Chipset Board
Pentium 200 MMX
64mb SDRAM
Windows 98se
Matrox Mill 2 8mb PCI
Voodoo 2 12mb PCI
Sound Blaster 32 CT3670 ISA
The problem I am having is Starcraft 1 lags whenever I click on a new character or building. It seems there is a delay in loading the audio for the character and causes the game to pause for a bit.
After a while the issue goes away as most of the sounds have been loaded.
The main starcraft file is copied to the HDD (so no CD needed) and it is a newer 20GB IDE drive (with DMA enabled), so I don't believe that is the issue.
I was thinking about changing the Sound Card but it seems this model is basically a AWE64, so I would assume ok.
I don't remember this happening even on my old Pentium 133.
Does anyone have any ideas?
