First post, by Ozzuneoj
Can we make a list of mice that have backward compatibility with older protocols when using adapters? I looked around online but didn't really find anything like this.
Please make a special note if:
  • The mouse is still available to purchase new, please include a link to it.
  • Only a specific version is known to work.
  • There are any known quirks (doesn't work in DOS with cutemouse, etc.).
Feel free to also mention mice that you know do NOT work with adapters.
USB Mice that DO work with PS/2 adapters:
Logitech Optical Mouse (Original blue one from ~2000)
Logitech MX500
Logitech MX518 (Original one from early\mid 2000s)
USB Mice that DON'T work with PS/2 adapters:
Logitech G402 Hyperion Fury
Reply 1 of 12, by EduBat
HP M-BT96a (a rebanded logitech) works
lenovo MO28UOA does not work
Reply 2 of 12, by kaputnik
Logitech MX400 laser mouse, from around 2007 iirc. Works with everything I've tried, used it with my retro machines for ages. It also seems completely insensitive to what surface you use it on, unlike most old optical mice.
Reply 3 of 12, by 1541
- Microsoft IntelliMouse "Classic" (balled - not produced anymore)
- Microsoft IntelliMouse Optical (not produced anymore)
- Microsoft Comfort Optical Mouse 3000 (not produced anymore)
- Microsoft Basic Optical Mouse (produced 2021)
- Microsoft Comfort Mouse 4500
- Logitech M-U0017
See also:
https://youtu.be/1UNOzkzLU_w
💾 Windows 9x resources (drivers, tools, NUSB,...) 💾
Reply 4 of 12, by ChrisK
- Logitech MouseMan Optical Dual (from around 2001)
RetroPC: K6-III+/400ATZ @6x83@1.7V / CT-5SIM / 2x 64M SDR / 40G HDD / RIVA TNT / V2 SLI / CT4520
ModernPC: Phenom II 910e @ 3GHz / ALiveDual-eSATA2 / 4x 2GB DDR-II / 512G SSD / 750G HDD / RX470
Reply 5 of 12, by MarmotaArmy
I have a HP mouse m150. Working without problems I even enabled the extra buttons using the intellimouse drivers 4.1.2 and selecting Intellimouse explorer as the mouse.
The mouse is rated 5V 100ma , just as the PS/2 port, maybe we should look at mice that have the same power draw for compatibility.
Reply 6 of 12, by mainframe98
Delock produced a USB mouse that came with a PS/2 adapter; https://www.delock.com/produkt/12534/dokumente.html. It is out of production but still sold, at least in Europe.
I use this one for a couple of 486-era machines. It works like a charm, although I haven't looked into driver support for the scroll wheel.
Reply 7 of 12, by MikeSG
- Microsoft IntelliMouse Explorer 4.0 (optical)
Reply 8 of 12, by MarmotaArmy
MarmotaArmy wrote on 2024-01-04, 14:51:
HP m150
Weird... I can't find info on the international HP web but there is in spanish (south america) . Maybe it's sold only in this region?
http://www.gaminghp.com/web/producto/792
Reply 10 of 12, by Disruptor
- Microsoft IntelliMouse Explorer 3.0 (optical)
Reply 11 of 12, by AlessandroB
and ehat about serial mouse that support ps/2? i have this serial logitech… someone know if it work with serial->ps/2 adapter?
Reply 12 of 12, by Kordanor
I have been using the "CHERRY WheelMouse" for a bit. A great mouse which works with PS2 and can be bought for just 10€.
The issue however, same as with the Microsoft Mouse I got, is that it's slightly too fast, even on slowest setting with Cutemouse. So for some games I actually need to use a different more memory consuming driver to slow it down further.
Now I got an Amiga and I am facing a similar issue there.
I am wondering how the speed is on these other mice, of if there is any PS2 compatible mouse which actually has a DPI switch.
