First post, by deksar
Hello there.
I finally found an Intel Core 2 Duo E6700 2.66 Mhz CPU for my motherboard (fastest CPU that it supports) from Aliexpress, waited one month for it to arrive.. Arrived, replaced my old CPU with it, and the result is blank screen with no beep. Feeling too sad..
The BIOS is already updated to the latest BIOS version: 1501
Any clue please?
P.S.: When I carefully check the CPU, I see something like on the picture. Could that be the reason of the problem?
Reply 1 of 6, by bogdanpaulb
https://theretroweb.com/motherboards/s/asus-p5pe-vm: 'supports some Conroe Core2Duo CPUs with iGPU disabled' , if the igpu is enabled you have to use fsb800.
Reply 3 of 6, by bogdanpaulb
Then it should have worked. I have a lga775 with 865 Gigabyte board and a lga775 ECS board with via PT880 Pro which don't support core2duo and they act the same when i put one (no post). What revision is your board ?
Reply 5 of 6, by bogdanpaulb
That looks like a 'surface scratch', i've seen worse and the cpu was still working, but you can test it on a newer lga775 board just to be sure. I have the https://www.gigabyte.com/Motherboard/GA-8I865 … -G-RH-rev-20#ov (rev.2) and does not support c2d, but as you see the later revs support it, so because you have the rev.1 of that board i'm thinking is the same in your case.
Reply 6 of 6, by deksar
It seems I will need to test it with an another motherboard.. Well, if I could find some.
Regarding the motherboard revision, the asus page says "ALL" I don't really think that's the main case.. 😒
(And since BIOS version 0604)
    24.1 KiB
