First post, by Msciej
I am using one of my old laptops, it has DOS 6.22 on it. The laptop has an external VGA port, how can I use it? I would like to use my external monitor, but whatever i try, the main inbuilt screen is the only one that works. Is there a DOS driver or will it require hardware rewireing? Obviously, it works fine when running windows. I dont need any dual/extended display.
Reply 1 of 5, by dr_st
Welcome to the forum. 😀
Check if there perhaps is a BIOS setting for default display.
Reply 2 of 5, by jmarsh
Does one of the F1-F10 keys have a picture of a monitor on it? Usually there's a separate "function" key you need to press with it to switch to using the external port.
Reply 3 of 5, by Msciej
There seems to be a dedicated FN button, but it does not work, i think it used to work only in windows, maybe i damaged the VGA port at one point, i will need to check. No bios setting for the default display. I vaguely remeber i had the same issue with this laptop and Linux, i think i solved it with a driver. So in your opinion this a hardware problem, not a driver?
Reply 4 of 5, by konc
Most probably it's a software issue. Often these machines had a BIOS option to always force a mode, but if this doesn't it's not unlikely that the output (or the fn keys) can only be enabled with software.
Sharing the exact laptop model could also help, maybe another member has the same and can help.
Reply 5 of 5, by Msciej
Its Samsung N130. I have found out that in case of that laptop the FN button works in Windows only, I should have the drivers CD somewhere, perhaps it has DOS drivers, who knows. Oddly, some FN buttons do work without windows but not the VGA port activation.
