First post, by Comos
- Newbie
Hi Everyone,
I would like to ask the owners of a PCChips M919 (Elpina) v3.4 B/F if their succeed with their BIOS update.Tried several times via the original AMI update utility which was able to identify the EEPROM as SST29EE010, but during update it just failed.
Then I tried also UniFlash, but this tool was unable even to detect the EEPROM type, so no luck either.I made the inspection of the board, where the jumpers are correctly set and no traces broken around the BIOS socket, so I have suspicion that the EEPROM might have a write protection, which is possible according to the datasheet.In the worst case I'll swap it with SST39SF010A which I have also on my PVI-486SP3 and should work from the principle.
any thoughts?
