First post, by brassicGamer
- Oldbie
Hello all.
Short question: does anyone know how is this card configured as primary or secondary? Long question follows.
I've got this really nice caching controller but have never been able to get it working, so I was wondering if anyone here has any experience with this card (or similar issues with different cards). It appears I have rev. 2 of the card, which has jumpers for configuring the IRQ. It's a slightly complicated and annoying issue so I'm going to break it down as much as possible, so that any possible misconceptions I've got can be noticed.
- As the card has its own BIOS, the hard drive must be set to 'Not Installed' in the system BIOS. Otherwise you get a 'HDD controller failure' message and the card appears broken.
- When I boot the computer, the card's BIOS displays on screen and the menu can be accessed to configure the card.
- It identifies as 'secondary' with the jumpers in the default configuration (floppy enabled, IRQ12, VL speed normal). Although it auto-detects the drive correctly, it will not allow me to boot the computer from a hard drive because the card is 'secondary'.
- When I change the IRQ to 14, the card suddenly identifies as 'primary', but it does not detect the attached drive and says it's not installed.
- When I change the IRQ to 15, I'm back to the card being secondary and the drive is recognised again.
I have tried the following things without success:
- Installing a normal ISA controller to act as a 'primary' controller but the system hangs (possibly an I/O clash). This isn't a solution anyway because DOS won't see the Promise card natively - a driver is required, so is a workaround at best.
- Different I/O addresses.
- A different VLB slot.
- A non-VLB graphics card.
So my main question is, how is this card configured as primary or secondary? It seems to be doing it automatically based on some kind of configuration (which can't just be the IRQ - that doesn't make any sense) but either way I can't seem to get control over it. The configuration menu provides no options for this. The graphics card is the only other card in this system. It's a 486DX2/66 with EISA.
Sadly I don't have another VLB system I can try it in.
