First post, by Jo22
Hi everyone,
Just saw some interesting video at YT.
Someone put a lot of work into creating a tiny 486 PC.
But here's the catch: It's an accurate model of a classic 486 PC, not just a small 486 setup.
Even the old tube monitor had been replicated, visually.
Quite a lot of work went into 3D printing all the individual parts. Impressive, isn't it? 😃
https://www.youtube.com/watch?v=vkuYGle9L20
Have fun.
Best wishes,
Jo22
Reply 1 of 8, by ThinkpadIL
What a cute little nonsense!
N.B. Btw, the tiniest 486 computer is this ...
The attachment a778b219527cc7e50b2342f442c6c7a2.jpg is no longer available
Reply 2 of 8, by Kreshna Aryaguna Nurzaman
Still has the room for 5.25" floppy drive, impressive. The monitor doesn't have to be small though.
Kreshna Aryaguna Nurzaman.
Reply 3 of 8, by Disruptor
Ha. He definitively needs an ISA ET4000 W32.
Reply 4 of 8, by Jo22
Yay! For Windows 3.x/95 and OS/2 the W32 is much better! ^^
DOS games and demos may prefer the AX version, AX also has a mode utility (CGA/EGA/MGA) and 8514/A emulation using RIXAI8.
Reply 5 of 8, by theelf
Jo22 wrote on 2023-04-23, 08:16:
Hi everyone, […]
Hi everyone,
Have fun.
Best wishes,
Jo22
Incredible!!!
i will love yo make me one, but 3D design is something i dont know.how to do
I wish i can find stl with all parts for a mini retro PC
Reply 6 of 8, by ThinkpadIL
Kreshna Aryaguna Nurzaman wrote on 2023-04-24, 05:42:
No it's not. Not even for 3.5" FDD. Take a look at the comparison with a normal size case. It is all dummy.
Reply 7 of 8, by wbahnassi
Nice it has that enclosure and screen. Points for the expansion cards and external IDE connector. I would also expose the FDD connector as well. A little concerned on heat dissipation.. does it vent well?
The tiniest build I could achieve with real devices is my lego PC.
The attachment 20221207_211239.jpg is no longer available
This is a P233-MMX with SB16ASP card, 5.25"/3.5" disk drives and a slot-loading CD drive.
Adding real drives expands the minimum dimensions quite a bit, and you need air room for the CPU and PSU to breathe.
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 8 of 8, by gerry
i like creative cases and builds like this (and the lego one wbahnassi - that is great!)
the small size makes for interesting challenges, especially if using 'normal' parts as much as possible
i don't have a 3d printer but making cases / parts for cases is something i'd want to do if i had one
