First post, by Jackhead
Another Exotic build that i finished.
This one is kind of special because it was a hybrid system with PCI and C-Bus. It was one of the last systems from NEC before the leave the pc-9821.
It runs a japanese windows98 SE . I managed to disable the onboard sound to get the PC9801-86 to work.
On the IDE bus is a 4GB CF adapter with the OS. On the internal SCSI bus (adaptec) is a SCSI2SD V6 with a 32GB SD as storage.
As GPU i installed a Voodoo Banshee. The other pci socket holds a USB-2.0 board.
I did a complete recap of the PSU and the mainboard with nichicons.
For the Sound i choose a 9801-86 with YM2608 chip and also a Roland MPU for Midi.
Here some pictures:
The attachment FugLd0NWIA0-ce2.jpg is no longer available
The attachment FugLd0UWIAgVFBp.jpg is no longer available
The attachment FufOojtWYAIxoDn.jpg is no longer available
The attachment FufOojqXoAUYhFG.jpg is no longer available
The attachment FueTEpMWAAIJeGm.jpg is no longer available
Win98SE: Asus XG DLS - 1x P3 Xeon SL4XY 900/100/2- SG Voodoo 5 6000 PCI - 1GB RAM ECC- Diamond Monster Sound MX300 - Roland MPU-401AT (Yucatan FX)
