Reply 20 of 24, by foxzflow
Today, I received a Coppermine Celeron 1100Mhz processor (1100/128/100 - 1,75v). I just plugged in the slotket and setup slotket with default configuration jumpers ("auto"). I plugged in the slot 1 and powered on the board. My surprise is that it did boot either 🙁
I tried to manually setup slotket for 100Mhz and manual voltage but no luck 🙁
What I see that is different from before is that motherboard LEDs are in a different status than before (all were RED using the other processors on the slotket).
Now is showing LED2 = GREEN, LED3 = GREEEN, LED4 = RED and LED5 = RED that manual states "Decompressing BIOS image to RAM for fast booting.".
My guess is that there is something wrong with the slotket because if I switch to slot 1 P3 500Mhz it works perfectly.
