First post, by tony359
- Member
Hi all,
I'm trying to get a Compact flash to work with my PS/2 model 30, 8086 variant.
I've got a glitchworks rev4 board which is working fine with a Pentium board.
I downloaded the "PS/2" ROM but that did not work as in the CF does not get recognised. Other versions cause the PS/2 to freeze at boot.
I was sent an old version from 2013 (XT) and that worked! I could see the CF, I could FDISK it, format it and install DOS 3.30 with "select".
However, the system freezes when it's time to boot. XTIDE says Booting C>>C and that's it, I have to power cycle. However if I boot via floppy, I can access the CF, see the files and everything.
I'm aware the PS/2 model 30 8086 is very limited when it comes to BIOS - which it doesn't have! So I'm wondering if I maybe need to do some special settings in the XTIDE ROM? I tried forcing CHS to emulate the existing 20MB HDD (which is disconnected) but that didn't work with the newest ROM. The old 2013 ROM I was sent is not recognised by XTIDECFG utility.
However, if I try to boot with my DOS 6.22 CF, it works (as long as I remove stuff like EMM386 and Himem!).
So there are two issues here: 1. newer ROM don't recognise the CF, 2. older CF works but not with DOS 3.3
Any help appreciated!
My Youtube channel: https://www.youtube.com/@tony359
