Reply 48980 of 59293, by ubiq
So I saw this.... thing listed on eBay and jumped on it. It's got an actual 440BX chipset on it, believe it or not. I didn't even notice the sneaky AGP slot - see it there?
The attachment s-l1600.jpg is no longer available
Anyway, it hasn't arrived yet and I have no plan for it, but I'll probably try to make it fit in some case it has no business being in. 🥴
Reply 48981 of 59293, by BitWrangler
Standard Def Steve wrote on 2023-04-30, 19:20:
Yay, it's garage sale season again! Picked up two boxes of promotional flash drives today. They range in size from 512MB - 2GB, and with write speeds barely hitting 2 MB/s, they are pretty much useless these days. But hey, $3/box, plus the fun shapes and colours totally won me over. 😜
I'd have jumped on that too, I like having different stuff on recognisably different drives, and it's always a few hundred MB here and there, rarely need modern "smallest" of 16GB.
Reply 48982 of 59293, by Repo Man11
ubiq wrote on 2023-05-01, 00:39:
It'd be cool for someone to make a video where they determine what AT form factor motherboard had the highest performance.
Reply 48983 of 59293, by Warlord
Looks to be a 44oLX, dead give away is the edo slots, still a neat board.
Reply 48984 of 59293, by amadeus777999
andre_6 wrote on 2023-04-30, 21:11:
amadeus777999 wrote on 2023-04-30, 12:41:
Most of your questions are (way) beyond my expertise. But when it comes to a Trinitron PC monitor with the brightness issue, th […]
andre_6 wrote on 2023-04-28, 21:16:
Hello, I looked everywhere for your reply, I read it and then totally forgot in which thread it was in!
I even created a new thread to try and obtain the answer, here: Sony CRT TVs and Monitors "breathing" and brightness problem - which caps/parts to replace to fix it?
But I can just delete it and ask here: could you please elaborate on the procedure to solve the "breathing" and brightness issue on Sony CRTs? I have that same problem with a small 1999 Black Trinitron, I adjusted the brightness to mitigate the issue of distorted geometry and it worked, but I assume it will only get worse with age, and that servicing it is inevitable. How did you proceed to do the service? What parts/capacitors did you replace, if that's the case, and if it's the same between Trinitron Monitors and TVs? Many thanks for your help, glad I could finally find your reply!
But when it comes to a Trinitron PC monitor with the brightness issue, the following procedure can be done...
https://www.youtube.com/watch?v=xH4fKpKLkBM
I have some of my stuff stored in the countryside(Crt, cable), so I can't provide much info as I can't test the procedure step by step to verify my memories.
The video should help though. Changing the resistor may not be a good option so better try the cable/software route.
I'll most likely buy a P260 crt in the next 2 weeks, so this should ease "re-hashing" what I did.
Thank you for your reply. It seems it is indeed different between Sony Monitors and TVs. The brightness issue in Monitors is a problem in itself and it doesn't warp the geometry per se. In my problem with the CRT TV it's the geometry that's clearly affected, which in turn can be alleviated via the brightness / screen adjustments. Shame, if the problem was the same all around I would have a better chance of tracking down the failing part that is to blame. If I ever find it out I'll post it in the thread I made
If you're going, or have to go, for a hardware service then maybe just re-capping the board(s) inside is one of the few things you could do.
A bad cap, or even worse, a few, can change a lot.
Keep us updated!
Reply 48985 of 59293, by dormcat
Warlord wrote on 2023-05-01, 03:13:
440LX +1. The second row "FW82443LX" and the fourth row "SL2KK" are clearly identifiable.
Reply 48986 of 59293, by weedeewee
dormcat wrote on 2023-05-01, 08:03:
It is also marked wrongly as having a 440BX here https://theretroweb.com/motherboards/s/procomp-informat-b684
While the alternate names kinda give it away it's indeed an 440LX
Do not ask Why !
Reply 48987 of 59293, by Minutemanqvs
Some new XPs, MPs and Phenoms. There is a Barton 3200+ with 400MHz FSB and a Thunderbird 1.4GHz in the lot, and fast Durons too.
Searching anything Nexgen, PM me if you have one. Also ATI Rage 128 PCI cards.
Reply 48988 of 59293, by Nexxen
Minutemanqvs wrote on 2023-05-01, 13:34:
Some new XPs, MPs and Phenoms. There is a Barton 3200+ with 400MHz FSB and a Thunderbird 1.4GHz in the lot, and fast Durons too. […]
I reported you for x rated material...
Can you add more? 🤣
3200+ and 1400, congrats!!
Duron 1800...
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 48989 of 59293, by BitWrangler
Repo Man11 wrote on 2023-05-01, 02:25:
Mid noughts, when the old school lunchbox portables could still be got for $0 to $50, I was pondering this and figured AT BX and Tualatin was the way to go for max grunt in AT form factor. I got hold of a PC Partner BX AT, but it barely does PIIIs, needs some BIOS mods etc before it will take a coppermine even. Anyway, there's 45 Baby AT/BX listed on TRW. These were around at the end of 90s because of the inverse of the problem we have now, then there were lots of AT cases and not enough or expensive ATX ones.
Reply 48990 of 59293, by LewisRaz
Amazing! But them being stacked like that is giving me anxiety! 😁
My retro pc youtube channel
Twitter
Reply 48991 of 59293, by whitepawn
Predator99 wrote on 2023-04-30, 20:41:
Yes works and gives a nice firework. Dont know what all the LEDs mean. […]
whitepawn wrote on 2023-04-30, 16:54:
Predator99 wrote on 2023-04-28, 19:41:
..and Apple II cards […]
Strange mix but seems to be worth the money I paid...
EDIT: The ROM on the POST-card will not do very much...
There are some pal chips on that POST card.They might be protected though.
Very good card.Does it work?
Also dont know about the PALs, my Minipro seems not to be able to read them.
@Predator99 i see.Do you have any back side pictures of POST card?
Reply 48992 of 59293, by Predator99
whitepawn wrote on 2023-05-01, 17:11:
Yes
The attachment IMG_8294r.jpg is no longer available
The attachment IMG_8292r.jpg is no longer available
Reply 48993 of 59293, by whitepawn
Predator99 wrote on 2023-05-01, 18:03:
Yes […]
Yes
@Predator99 Thank you. I always liked old POST cards. I asked for reverse engineering pcb. Maybe i will reverse engineer this.
Reply 48994 of 59293, by Minutemanqvs
Nexxen wrote on 2023-05-01, 14:50:
I reported you for x rated material... Can you add more? LOL […]
Can you add more? 🤣
Duron 1800...
Yep, the Duron 1800 is the fastest produced, an Applebred core.
Reply 48995 of 59293, by gerry
LewisRaz wrote on 2023-05-01, 15:29:
wait till they're wired up to each other to become the ultimate vintage multi core! 😀
Reply 48996 of 59293, by rasz_pl
whitepawn wrote on 2023-05-01, 18:38:
Yes […]
Yes
It feels like someone was a fan/had cheap access to PALs. Asus used to make POST card like this, just three PALs and LED display 😀. DIY:
https://bbright.tripod.com/information/postcard.htm
https://www.andavno.com/?p=87 https://www.andavno.com/?p=619
Reply 48997 of 59293, by Deksor
Could you please send us a good picture to illustrate this page ? https://theretroweb.com/motherboards/s/procomp-informat-b684
Thanks 😀
Reply 48998 of 59293, by Nexxen
Minutemanqvs wrote on 2023-05-01, 18:41:
Can you add more? 🤣
Duron 1800...
Maybe my mistake but are you going to bench them?
It would be interesting to have all the cpus tested and benched on the same platform.
Reply 48999 of 59293, by ubiq
Deksor wrote on 2023-05-01, 20:11:
Thanks 😀
Absolutely, when it arrives! And yes, this is where I looked it up and was mislead about the 440BX - the linked manual has it as an LX.
