First post, by feipoa
- l33t++
I've been slowly prepping for an Am5x86-180 build but ran into a snag when trying to use either an Adaptec 2940U2W SCSI or Promise Ultra100 TX2 IDE controller on the Lucky Star LS-486E rev.D. I'm doing my tests at 2x60 for now.
If I leave jumper JP16 on the position such that PCI = FSB, the SCSI card doesn't find the HDD. If I set PCI = 1/2*FSB, the HDD is found, but when the system is supposed to boot, it just sits there on POST screen.
If I leave jumper JP16 on the position such that PCI = FSB, the Ultra100 IDE card boots Windows 95, but isn't reliable. For example, if I play an mp3 with Winamp 2.05, the file plays fine, but locks up the system. If I set PCI = 1/2*FSB, the system just sits there when it is supposed to boot after POST (same with SCSI).
If I do the same tests with a 50 MHz FSB, there is no problem. The MB-8433UUD has no issue with 1/2*60 and 1/2*66. Something is up with the LS-486E for these frequencies. Anyone know what's going on and where to start looking for a fix?
Here's the PCI waveform for CLK at 60 MHz:
The waveform with PCI = 1/2*60 MHz:
I also took a look at the FFT for 1/2*60 MHz:
The waveform at 50 MHz:
And the waveform at 1/2*50 MHz (this configuration works):
The only aspect which really stood out from these waveforms is that the voltage swing for 30 MHz (doesn't work) is a little higher than at 25 MHz (works).
I did discover that the onboard IDE controller appears functional at 60 MHz, but I was hoping to go with something a bit faster on a PCI expansion card. Why might 1/2*60 and 1/2*66 MHz not be working for PCI hard drive expansion cards and what can be done to correct for this shortcoming?
