Reply 20 of 26, by Salient
imi wrote on 2021-02-12, 12:19:
is there any listening example of the differences between the old old one and the old rev.1?
Here you can hear the difference with the credits track of Dune II.
Reply 22 of 26, by imi
yeah let me repeat that to be more clear ^^
I was wondering about the difference between:
OLD Roland MT-32 up to serial number 851399
OLD Roland MT-32 revision 1 serial numbers 851400 - 950499
Reply 24 of 26, by Dimitris1980
I believe the best combination is a Roland MT32 (old unit) and a Roland CM32L / CM64 / LAPC-I.
- Macintosh LC475, Powerbook 540c, Macintosh Performa 6116CD, Power Macintosh G3 Minitower (x2), Imac G3, Powermac G4 MDD, Powermac G5, Imac Mid 2007
- Cyrix 120
- Amiga 500, Amiga 1200
- Atari 1040 STF
- Roland MT32, CM64, CM500, SC55, SC88, Yamaha MU50
Reply 25 of 26, by stalk3r
NewRisingSun wrote on 2021-02-12, 19:36:
OP is asking about two versions of "old-type" MT-32 (ASSY 7937731000 vs. ASSY 793741000), not about "old-type" vs. "new-type" (ASSY 7937731001) MT-32.
All that the later "old-type" MT-32 changes is to consolidate the circuit board design by changing the package type of the LA32 chip and by replacing EPROMs with mask ROMs. Control and sample ROM content are identical by all accounts. See the MT-32 Service Notes Second Edition.
These ASSY numbers are not too intuitive with the MT-32s it seems. I have one with ASSY 7937731001 which supposed to be the "new-type" MT-32, however it is missing the headphone jack, and the PCB layout looks exactly like the "old-type", except it already has the QFP type LA32 chip. Also, it has the old v1.7 ROM version instead of v2.0.
Indeed, per Service Notes 3rd edition :
https://i.imgur.com/qhkI36B.pngqhkI36B.png
So it seems the real differentiator between the "old-type" and "new-type" MT-32 is the existence of the headphone jack (i.e. completely redesigned PCB), rather than the ASSY number itself.
Reply 26 of 26, by Salient
I find the "old type" MT-32 most suitable as well.
Although I have both the MT-32 as well as a CM-32 (and a CM-500 for that matter), all of those are stored away for years to come probably, I must admit I am more than happy to use serdaco's MT-32 Pi HAT with MT32Pi. Saves a lot of deskspace as well and even with a half decent SC-55 soundfont I find this one little device sufficient to cover all my DOS gaming needs for the time being.
