Reply 49060 of 59291, by Munx
tauro wrote on 2023-05-07, 08:20:
What could a Win7 computer run that Win10/11 doesn't run?
A lot of games that had a CD-check or many other forms of DRM.
For example, the only version of Red Alert 2 that I can run on my Windows 10 machine is the one from origin, as W10 refuses to run the CD installer. Even after that, I needed a community made patch to run it an acceptable framerate.
On Windows 7 meanwhile it's just a straight install and a single line edit on an .ini file to avoid slowdowns during explosions.
My builds!
The Underdog - The budget K6
Reply 49061 of 59291, by Turbo ->
Bought two AGP cards and two sticks of 512 Mb SDR Ram. All untested.
Reply 49062 of 59291, by rasz_pl
Munx wrote on 2023-05-07, 11:48:
and juggling CDs to play games? Il take copying 2 files (exe and directdraw overlay) over using CD any day.
Reply 49063 of 59291, by BitWrangler
Turbo -> wrote on 2023-05-07, 11:48:
That ASUS 9600XT looks cool, hope it works for you, last real AGP flagship GPU ???
Reply 49064 of 59291, by Munx
rasz_pl wrote on 2023-05-07, 12:48:
I'll take using a no-cd patch with the CD version over having to start up origin each time any day.
My builds!
Reply 49065 of 59291, by DundyTheCroc
BitWrangler wrote on 2023-05-07, 13:24:
Maybe it is 9800XT 😉
Reply 49066 of 59291, by Brawndo
Brawndo wrote on 2023-05-05, 17:58:
First, an ASUS P5N32-E SLI socket T (775) motherboard, which is the same board I had when I built my first Core2Duo PC with an Intel E6600. I still have that same E6600 CPU but I might stick the QX6700 CPU I currently have in another PC in this one, not sure yet. Also not pictured are two brand new Nvidia 7950 GTs which I will run SLI. This will be a mostly period correct 2006-2007 system running XP.
Well I'm 0 for 1 so far on the new acquisitions, the P5N32-E SLI will not POST at all using known good components from another system, so I'll have to return it. That's a huge bummer. Hopefully the other two boards work.
Maybe it's just me but it seems like there's a lot more crap being sold on ebay these days. I've had to send more stuff back just in the previous year than the entire 23 years I've been buying on eBay prior. You would think sellers wouldn't be so quick to sell used stuff without testing it before shipping it as they have to eat the return shipping. Or if you absolutely can't test it, just sell it for parts.
Reply 49067 of 59291, by dormcat
DundyTheCroc wrote on 2023-05-07, 15:29:
Asus A9800XT/TVD indeed. With 130 nm lithography and lower TDP, 9600 does not require any external power; OTOH 9500/9700 require floppy 4-pin connectors, while the flagship 9800 requires a standard Molex 4-pin.
It was on par with or better than FX 5900 Ultra (a dual slot card) and outperformed FX 5900 (the fastest single slot card NVIDIA could offer back then). Really an excellent find. 👍
Reply 49068 of 59291, by chrismeyer6
Brawndo wrote on 2023-05-07, 16:13:
Stupid question did you use a new bios battery? I've had a large number of motherboards old and new either not power on/post or just behave and strange unpredictable ways with missing or dead/low bios batteries.
Reply 49069 of 59291, by Dmetsys
That would be the 9800XT. Nvidia's would have been the FX5900, before they started using bridge chips on their PCI-E offerings to sell AGP variants.
NF7-S 2.0 | 2500+ @ 3200+ | 9700 Pro | Audigy2 ZS
CUV4X 1.03 | PIII-933 | MX400 | Live! Value 4670
P5A-B | K6-2 450 | TNT2 | AWE64 Value
4DPS | Am5x86-P75 | S3 Vision864 | SB16 CT2290
Reply 49070 of 59291, by tauro
A lot of games that had a CD-check or many other forms of DRM. […]
I see, very interesting example. So Win7 is more retro-compatible with very old CD-based games.
My point was this, is there any Win7 game (not compatible with Win98, not compatible with WinXP) that can't run on Windows 10 or 11?
Reply 49071 of 59291, by Brawndo
chrismeyer6 wrote on 2023-05-07, 19:47:
I did not try a new CMOS battery. I've never had a board not boot with a dead or missing battery, they just don't retain settings or date/time, so that would be news to me. Worth a shot I guess. I'm going to try a few more things before throwing in the towel though. I really want it to work.
Reply 49072 of 59291, by cyclone3d
Dmetsys wrote on 2023-05-07, 21:39:
The FX5950 Ultra was the fastest FX card from Nvidia, not the 5900.
Nvidia also did some PCIe FX cards that used a bridge chip. The PCX5300, 5750 and 5900.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 49073 of 59291, by Minutemanqvs
I found a passively cooled Radeon HD 3650 AGP for very cheap locally, it's my most powerful AGP card now 😀
I just had to re-apply new thermal paste as the old one was completely dry (and it seems that today everyone is doing that to be cool).
Searching anything Nexgen, PM me if you have one. Also ATI Rage 128 PCI cards.
Reply 49074 of 59291, by chrismeyer6
Brawndo wrote on 2023-05-08, 05:00:
I was totally dumbfounded the first time I figured that out. So I went back through my container of non-working motherboards and trying new batteries had 15 suddenly spring to life. I did as a control pull the battery and try again and sure enough they all played dead. So it's one of my go-to troubleshooting steps. My sons socket A system with a Abit KT7a-raid gets weird blue screens or hangs at post when it's battery gets low and my EVGA 680i based XP system will not post with a dead battery.
Reply 49075 of 59291, by Munx
tauro wrote on 2023-05-08, 03:31:
I have not encountered such and I doubt there would be many, as XP support was ending when publishers were stopping to use crap like securom and moved on to win10 compatible garbage like denuevo.
The main advantage With 7 would be very wide (though not perfect) compatibility, which ranges from W9x stuff all the way up current-day titles.
My builds!
Reply 49076 of 59291, by aaronkatrini
Love that ASUS 9800XTX! I had one exactly like that. Man that thing is all copper and really heavy 😀
Reply 49078 of 59291, by debs3759
I would guess it's a memory expansion card, as it has 8 RAM chips on it. Possibly for a specific motherboard.
