Hp VS17 lcd
First post, by djsabreblade
I've been trying to remove the crappy looking greenish-blue hue from this 17 inch lcd monitor the VS17 (april 2005 manufactured) i have it connected to my old radeon X1650 pro 512mb using vga. All the monitor needs is to add some more rose/red color but the omega drivers with ati tray tools color aren't good enough for fine tuning colors. I need some other tool to boost colors that works on XP. Any suggestion?
Reply 1 of 4, by TheMLGladiator
The program PowerStrip might be helpful. I haven't used it personally so I can't say for sure.
Reply 2 of 4, by djsabreblade
Thank you. Will try
Reply 3 of 4, by Roman555
Monitors usually have settings in OSD-menu to adjust colors
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 4 of 4, by djsabreblade
it does but i still can't get a color scheme that looks good. even adjusting red just makes everything look deep red. i need just a bit of rose to soften the green/blue a bit to match my Dell e177fpb. will try PowerStrip.
