TinyLlama (Vortex86EX SBC)
Reply 540 of 659, by ExplodingLemur
I printed the case using Hatchbox grey PLA for the bottom half and PrintedSolid Jessie 500 beige PLA for the top half and buttons and I'm quite happy with that color combo 😀 I was going for a 90s Packard Bell desktop look and it definitely hits that note. I did modify the case a bit for extra ventilation though I think I need to re-print it without the top vents opened up. I may also try to get a spot in the front for the MT32-Pi's OLED. (BTW, thanks for posting the STEP files rather than just STLs, @Eivind!) Prusa i3 Mk3, 0.6mm nozzle, 0.3mm layers, 15% infill.
Reply 542 of 659, by iabhua
Sukerbole wrote on 2023-05-15, 19:27:
Just was wondering were people got the DMP stuff.
It seems that the paypal option is gone and the email address of DMP webshop does not work.
https://shop.dmp.com.tw/INT/products/25
This is where I got mine.
You could try wdl systems icop:
https://www.wdlsystems.com/ICOP-VEX-SOM-Vorte … DDR3-40C-to-85C
They are more expensive though.
Reply 543 of 659, by Sukerbole
iabhua wrote on 2023-05-15, 19:36:
https://shop.dmp.com.tw/INT/products/25 […]
Thanks. Tried the DMP site however was not able to pay.
shop@dmp.com.tw email does not work. Anybody have a working email from them?
Could ofcourse try info@.. That one did not return.. Now let’s wait..
Reply 545 of 659, by Sukerbole
You mean shop@dmp.com.tw?
No that one does not work:
shop@dmp.com.tw
host assp.dmp.com.tw [61.220.30.140]
SMTP error from remote mail server after end of data:
550 5.7.1 No such mail drop defined
Was able to get in touch with them and order the boards.
Reply 546 of 659, by Aaron707
Just thought I would share that I figured out a solution for the SD-Card activity LED . Used a yellow 3mm LED (1.9-2.4V) and 1K resistor on positive leg of LED. Wired negative leg to Data0 of the SD card since the data line is normally pulled up when not operating. And positive leg to VCC (VDD pin 4) .Works great and only illuminates when there is activity. I am using an SD-card extender so that is what I wired this too, not directly to the TinyLlama PCB.
    454.29 KiB
Reply 547 of 659, by ExplodingLemur
I wonder what the spec'd drive current is on that line? I'd feed a transistor gate with that pin rather than use it to run an LED directly just to be cautious.
Reply 548 of 659, by Eivind
Aaron707 wrote on 2023-05-23, 22:53:
That's cool! Did you experiment with using the different sd card signals and found D0 to work the best?
ExplodingLemur wrote on 2023-05-24, 01:03:
I think you mentioned using a transistor a few pages back, Aaron? However, using a LED and resistor as you described would only draw a current of 1-2mA - and since each pin's current driving on the Vortex86EX is spec'ed as 8mA (though, it doesn't talk about sourcing or sinking), I'm not surprised it seems to work just fine!
The LlamaBlaster sound card
ITX-Llama motherboard
TinyLlama SBC
Reply 549 of 659, by Aaron707
I only tested with D0 signal. I found this video https://youtu.be/SsPOobvoBe8 that described the process (in comments). Seemed much easier to implement than a transistor. Working great so far. If someone finds a better solution please share! It is hard to find much info on adding activity indicator to SD card slot outside of the RaspberryPi circles. And most others only discuss SPI mode.
Reply 550 of 659, by rasteri
With relatively high-speed devices like SD cards there's more to consider than just current carrying capacity, I would be worried about upsetting signal integrity on certain combinations of card/OS/transfer mode. If it works on your setup then great, but I wouldn't be using it in situations where reliability is important.
Reply 551 of 659, by ahmadexp
Hello everyone,
I am new to this amazing project. I got super excited about the Tinyllama 2 and I ordered the PCB in White and hand assembled all the components. Here are some pictures. Then I went with a clear resin 3D print of the box. Interestingly, I figured out to place the 0.96" OLED right about the buttons. Here are some pictures.
Special thanks and congratulations to Eivind for this amazing project.
    367.08 KiB
    1.99 MiB
Reply 552 of 659, by Eivind
ahmadexp wrote on 2023-05-31, 14:17:
Hello everyone,
Nice touch with the white PCB and clear case! Hope you'll get the wavetable adapter soon, if it hasn't reached you already! 👍
TinyLlama SBC
Reply 553 of 659, by ahmadexp
I just got it and I am going to print the tall version of the upper case to be able to put it on.
Just wondering, why do we need to move the PCM board to the adapter? Aren't the same I2S wires available via the RPi connector?
Reply 554 of 659, by Eivind
ahmadexp wrote on 2023-06-01, 02:15:
Yes, but not the analog audio lines! 😉 To elaborate, the analog output audio from the DAC is routed back into the CS4237B chip to be mixed in with everything else.
TinyLlama SBC
Reply 556 of 659, by Eivind
ahmadexp wrote on 2023-06-01, 05:11:
Oh I see, so the wavetable outputs in analog then. That's why you needed to mix it all together with the PCM before sending it to the line in of the crystal.
Yep, the path is either:
CS4237B->MIDI->RPi->I2S->DAC->analog audio->CS4237B or
CS4237B->MIDI->wavetable board->analog audio->CS4237B
TinyLlama SBC
Reply 558 of 659, by Eivind
ahmadexp wrote on 2023-06-01, 16:56:
Sorry if this is a noob question. On the keyboard I get "Insert mode" enabled after every press of Enter. This must be a bug, right?
Hmmm...not sure if I've seen this before. Are you running DOSKEY? Could it be that one messing it up (check its settings)?
TinyLlama SBC
Reply 559 of 659, by rasteri
Have you tried a different keyboard? Maybe HIDMAN is being weird...
