First post, by SSTV2
I can't get L2 cache work in this motherboard with a am5x86 CPU and I have no clue why is that, L2 works perfectly fine with am486DX4. I have compared both of these CPUs pinouts and according to the datasheets - both are identical in pinout 😕 Has anyone dealt with this problem before?
The attachment dx4.png is no longer available
The attachment am5x86.png is no longer available
Reply 1 of 12, by sKeletoN_SN
I actually have the exact same problem right now. Did you happen to find any clue about this issue?
Reply 2 of 12, by weldum
the motherboard may require a bios update, remember that the "L2" cache on 486 motherboards is on the motherboard, the processor has nothing to do here
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
Reply 3 of 12, by treeman
most likely the bios, I have a vlb board with a umc chipset and eveything works with L2 except a 5x86
Reply 4 of 12, by SSTV2
Not yet, I had to postpone researth on this matter. This motherboard uses a UMC UM82C482/UM82C481/UM82C206F chipset. I believe L2 not being detected issue is more chipset related than BIOS. I have another MB with exact same chipset, I'll test it too, some time later.
Reply 5 of 12, by treeman
mine is UC4914-G using a um82c491f it detects l2 on a overdrive dx4 100 but not amd 5x86 133 they both have 16k L1 so I don't think its a larger L1 size the problem
Reply 6 of 12, by Gulzyee
Hi I have also run into this problem with a VL486 motherboard with UMC chipset (Stason https://stason.org/TULARC/pc/motherboards/U/U … -486-VL486.html).
Am5x86 133 won't recognise L2 cache. FYI Pentium Overdrive 83Mhz also does not recognise L2 cache (but these are known to have cache comapitibility problems). I have set cache jumpers for 64k, 128k and 256k and it made no difference. Cache chips are Winbond 15ns x 8 and one 10ns (TAG). DX-33, DX2-66 and DX2-80 detect the L2.
BIOS is "IPEX ITG IPX-UM-486IV6201 04/08/1993"
AMI BIOS string "40-0100-001131-00101111-111192-UMC480-H"
I have an EPROM reader and UV eraser. I can provide a copy of the AMI BIOS if this can be modified by someone more intelligent than me?
Thanks all, look forward to your suggestions.
Reply 7 of 12, by Gulzyee
SSTV2 wrote on 2019-08-05, 22:12:
Hi SSTV2, did you get a chance to test with your other motherboard with same chipset? If yes, what was the outcome?
I did some further testing and I reduced the bus speed to 20mhz and ran the processor at 80mhz and 60mhz. But still the L2 cache won't detect.
Reply 8 of 12, by SSTV2
both motherboards were tested thoroughly (UM486V and GA-486VM), but neither could detect L2 cache with a 5x86 CPU inserted. I had tried all possible BIOS settings and jumper configurations, related to L2 cache, but nothing could make it work, even tried various BIOS images from chipset-compatible motherboards, including one MRBIOS image - no go. I think this issue is related to the outdated chipset (in relation to 5x86), the UM82C480 was introduced in 1991 for 386/early 486 CPUs, so some incompatibilty can be expected with its cache controller. By the way, this chipset doesn't support WB cache mode, better stick with a PCI supporting chipset, if you wish to max out the performance of a 5x86.
Sorry for the delayed reply, after the forum UI update, I rarely browse here.
Reply 9 of 12, by Gulzyee
Many thanks for your assistance SSTV2. I managed to get my Am5x86 running at 150mhz using 3 x 50mhz. So this somewhat compensates for the lack of L2. It is definitely faster than an dx2-80 with 256kb l2 enabled. Now just need a VLB IDE card capable of running at 50MHz for some extra performance.
Reply 10 of 12, by The Serpent Rider
Am5x86 150-160Mhz without L2 cache is more or less equal to 120Mhz 486DX4 with L2 cache.
Reply 11 of 12, by SSTV2
After the am5x86 CPU upgrade in the PCI 486 system with a more stable one, I had the old one lying around unused for a while, so I decided to take another look at the am5x86 and UM82C480 chipset incompatibility problem with the L2 cache.
My previous assumption, that the chipset is the main cause of this incompatibility - is wrong, it's indeed the outdated BIOS that does not enable L2 cache with the said CPU, intel DX4 ODPR and P24T (as seen here @pshipkov) are also affected. I found three different AMI BIOS versions for this ECS UM486V motherboard and all of them are built on 11/11/92 core, latest one being ver. 2.2 with the date code of 11/19/93, unfortunately, it's no different than the previous two versions regarding the L2 cache detection.
I tried tricking the BIOS into seeing all 486 CPUs as 486 DX2 in the POST summary screen, by changing one mask byte from B3 to B6 (found @32Dh of all the ECS 11/11/92 core versions) in the CPU detection routine, but that didn't help, routine's task seems to be just visual. Level 2 cache is enabled/disabled long before the POST summary screen appears.
Eventually I stopped experimenting with the original BIOS because I didn't know exactly what to look for and it didn't help that I had to rewrite the BIOS every time I made changes. Emulators didn't help here either, because they don't properly emulate the cache operation.
Now for the good news. The UM82C480 chipset can indeed work with an am5x86 and L2 cache enabled, I was able to find two BIOS images that properly detected L2 cache, one was from MRBIOS, the other from Phoenix. The previous MRBIOS image I tried was version 1.44 and the new one is version 1.65.
Speedsys results, am5x86 @ 163MHz in 3x mode:
The attachment 163MHz.png is no longer available
Here are some more interesting snippets of the disassembled AMI BIOS, in case anyone decides to find out exactly why the L2 cache doesn't work with the newer CPUs. Disassembled by IDA 6.1, AMI BIOS of GA-486VM, core 11/11/92.
CPU type detection routine:
F000:442C ; =============== S U B R O U T I N E =======================================
F000:442C
F000:442C
F000:442C sub_F442C proc near ; CODE XREF: sub_F4265+Cp CHECK IF 286 CLASS CPU
F000:442C pushf
F000:442D cli
F000:442E mov ax, 0F000h
F000:4431 push ax
F000:4432 popf
F000:4433 pushf
F000:4434 pop ax
F000:4435 and ah, 0F0h
F000:4438 mov si, 475Eh
F000:443B jz short loc_F449E ;CALL sub_F4248 STRING DISPLAY
F000:443D smsw ax
F000:4440 or ah, ah
F000:4442 jz short loc_F4474
F000:4444
F000:4444 loc_F4444: ; CODE XREF: sub_F442C+4Fj CHECK IF 386 CLASS CPU
F000:4444 push ax
F000:4445 mov eax, cr0
F000:4448 push eax
F000:444A and al, 0EFh
F000:444C mov cr0, eax
F000:444F mov eax, cr0
F000:4452 test al, 10h
F000:4454 pop eax
F000:4456 mov cr0, eax
F000:4459 pop ax
F000:445A mov si, 473Eh
F000:445D jnz short loc_F4468
F000:445F or ah, ah
F000:4461 jnz short loc_F449C ;MOV AH FFH, THEN CALL sub_F4248 STRING DISPLAY
F000:4463 mov si, 477Eh
F000:4466 jmp short loc_F449C ;MOV AH FFH, THEN CALL sub_F4248 STRING DISPLAY
F000:4468 ; ---------------------------------------------------------------------------
F000:4468
F000:4468 loc_F4468: ; CODE XREF: sub_F442C+31j
F000:4468 mov si, 474Eh
F000:446B or ah, ah
F000:446D jnz short loc_F449C ;MOV FF TO AH, THEN CALL sub_F4248 STRING DISPLAY
F000:446F mov si, 476Eh
F000:4472 jmp short loc_F449C ;MOV FF TO AH, THEN CALL sub_F4248 STRING DISPLAY
F000:4474 ; ---------------------------------------------------------------------------
F000:4474
F000:4474 loc_F4474: ; CODE XREF: sub_F442C+16j CHECK IF 486 CLASS CPU
F000:4474 mov al, 0B3h ; '¦'
F000:4476 call sub_FEE94
F000:4479 test al, 4 ; B3 AND 4 = 0
F000:447B jnz short loc_F4444 ; IF NOT 0, MUST BE A 386
F000:447D test al, 2 ; B3 AND 2 = 2
F000:447F mov si, 470Eh ; "80486DX2" STRING
F000:4482 jnz short loc_F449C ;MOV FF TO AH, THEN CALL sub_F4248 STRING DISPLAY
F000:4484 int 11h ; EQUIPMENT DETERMINATION
F000:4484 ; Return: AX = equipment flag bits
F000:4486 test al, 2
F000:4488 mov si, 471Eh ; "486DX or 487SX" STRING
F000:448B jnz short loc_F449C ;MOV FF TO AH, THEN CALL sub_F4248 STRING DISPLAY
…Show last 258 lines
F000:448D                 mov     al, cs:byte_FB5B5
F000:4491 call sub_F8300
F000:4494 mov si, 46FEh ; "80486" STRING
F000:4497 jz short loc_F449C ;MOV FF TO AH, THEN CALL sub_F4248 STRING DISPLAY
F000:4499 mov si, 472Eh ; "80486SX" STRING
F000:449C
F000:449C loc_F449C: ; CODE XREF: sub_F442C+35j
F000:449C ; sub_F442C+3Aj ...
F000:449C mov ah, 0FFh
F000:449E
F000:449E loc_F449E: ; CODE XREF: sub_F442C+Fj
F000:449E call sub_F4248
F000:44A1 popf
F000:44A2 retn
F000:44A2 sub_F442C endp
Strings at the summary screen:
F000:19B0 db 10h
F000:19B1 db 14h
F000:19B2 db 19h
F000:19B3 db 21h ; !
F000:19B4 db 28h ; (
F000:19B5 db 32h ; 2
F000:19B6 db 42h ; B
F000:19B7 db 50h ; P
F000:19B8 db 4Dh ; M
F000:19B9 db 48h ; H
F000:19BA db 7Ah ; z
F000:19BB db 20h
F000:19BC db 43h ; C
F000:19BD db 50h ; P
F000:19BE db 55h ; U
F000:19BF db 20h
F000:19C0 db 43h ; C
F000:19C1 db 6Ch ; l
F000:19C2 db 6Fh ; o
F000:19C3 db 63h ; c
F000:19C4 db 6Bh ; k
F000:19C5 db 0Dh
F000:19C6 db 0Ah
F000:19C7 db 0
F000:19C8 db 4Dh ; M
F000:19C9 db 48h ; H
F000:19CA db 7Ah ; z
F000:19CB db 20h
F000:19CC db 44h ; D
F000:19CD db 58h ; X
F000:19CE db 32h ; 2
F000:19CF db 20h
F000:19D0 db 43h ; C
F000:19D1 db 50h ; P
F000:19D2 db 55h ; U
F000:19D3 db 20h
F000:19D4 db 0Dh
F000:19D5 db 0Ah
F000:19D6 db 0
F000:19D7 db 4Bh ; K
F000:19D8 db 42h ; B
F000:19D9 db 20h
F000:19DA db 43h ; C
F000:19DB db 41h ; A
F000:19DC db 43h ; C
F000:19DD db 48h ; H
F000:19DE db 45h ; E
F000:19DF db 20h
F000:19E0 db 4Dh ; M
F000:19E1 db 45h ; E
F000:19E2 db 4Dh ; M
F000:19E3 db 4Fh ; O
F000:19E4 db 52h ; R
F000:19E5 db 59h ; Y
F000:19E6 db 0Dh
F000:19E7 db 0Ah
F000:19E8 db 0
F000:19E9 db 0
F000:19EA db 0
F000:19EB db 4
F000:19EC db 10h
F000:19ED db 0
F000:19EE db 2
F000:19EF db 18h
F000:19F0 db 0
F000:19F1 db 1
F000:19F2 db 1Ch
F000:19F3 db 80h ; Ç
F000:19F4 db 0
F000:19F5 db 1Eh
F000:19F6 db 40h ; @
F000:19F7 db 0
F000:19F8 db 1Fh
F000:19F9 db 20h
F000:19FA db 0
F000:19FB db 0FFh
F000:19FC
F000:19FC ; =============== S U B R O U T I N E =======================================
F000:19FC
F000:19FC
F000:19FC sub_F19FC proc near ; CODE XREF: sub_F4234+9p
F000:19FC mov ax, cs:word_F82E6
F000:1A00 call ax
F000:1A02 mov al, 92h ; 'Æ'
F000:1A04 call sub_F8DBA
F000:1A07 test al, 1
F000:1A09 jz short loc_F1A2C
F000:1A0B mov al, 93h ; 'ô'
F000:1A0D call sub_F8DBA
F000:1A10 and al, 1Fh
F000:1A12 mov bl, al
F000:1A14 mov si, 19E9h
F000:1A17
F000:1A17 loc_F1A17: ; CODE XREF: sub_F19FC+25j
F000:1A17 lods byte ptr cs:[si]
F000:1A19 cmp al, 0FFh
F000:1A1B jz short loc_F1A7F
F000:1A1D cmp al, bl
F000:1A1F lods word ptr cs:[si]
F000:1A21 jnz short loc_F1A17
F000:1A23 call loc_F09FD
F000:1A26 mov si, 19D7h
F000:1A29 call sub_FF52E
F000:1A2C
F000:1A2C loc_F1A2C: ; CODE XREF: sub_F19FC+Dj
F000:1A2C ; sub_F19FC+86j
F000:1A2C call sub_F2C27
F000:1A2F jz short locret_F1A7E
F000:1A31 mov ax, 0B3B3h
F000:1A34 call sub_FEE94
F000:1A37 test al, 2
F000:1A39 jz short loc_F1A5E
F000:1A3B mov ax, 0B3B3h
F000:1A3E call sub_FEE94
F000:1A41 and al, 70h
F000:1A43 shr al, 4
F000:1A46 xor ah, ah
F000:1A48 mov si, 19B0h
F000:1A4B add si, ax
F000:1A4D mov al, cs:[si]
F000:1A50 xor ah, ah
F000:1A52 call loc_F09FD
F000:1A55 mov si, 19C8h
F000:1A58 call sub_FF52E
F000:1A5B jmp short locret_F1A7E
F000:1A5B ; ---------------------------------------------------------------------------
F000:1A5D db 90h ; É
F000:1A5E ; ---------------------------------------------------------------------------
F000:1A5E
F000:1A5E loc_F1A5E: ; CODE XREF: sub_F19FC+3Dj
F000:1A5E mov ax, 0B3B3h
F000:1A61 call sub_FEE94
F000:1A64 and al, 70h
F000:1A66 shr al, 4
F000:1A69 xor ah, ah
F000:1A6B mov si, 19B0h
F000:1A6E add si, ax
F000:1A70 mov al, cs:[si]
F000:1A73 xor ah, ah
F000:1A75 call loc_F09FD
F000:1A78 mov si, 19B8h
F000:1A7B call sub_FF52E
F000:1A7E
F000:1A7E locret_F1A7E: ; CODE XREF: sub_F19FC+33j
F000:1A7E ; sub_F19FC+5Fj
F000:1A7E retn
F000:1A7F ; ---------------------------------------------------------------------------
F000:1A7F
F000:1A7F loc_F1A7F: ; CODE XREF: sub_F19FC+1Fj
F000:1A7F call sub_F8D72
F000:1A82 jmp short loc_F1A2C
F000:1A82 sub_F19FC endp
Cache (internal?) enabling/disabling:
F000:8C42 loc_F8C42: ; CODE XREF: sub_F8B87+B5j
F000:8C42 mov eax, cr0
F000:8C45 and eax, 9FFFFFFFh
F000:8C4B mov cr0, eax
F000:8C4E cli
F000:8C4F mov eax, cr0
F000:8C52 or eax, 40000000h
F000:8C58 mov cr0, eax
F000:8C5B mov ax, 14C0h
F000:8C5E out 22h, al
F000:8C60 jcxz short $+2
F000:8C62 jcxz short $+2
F000:8C64 xchg ah, al
F000:8C66 out 23h, al
F000:8C68 jcxz short $+2
F000:8C6A jcxz short $+2
F000:8C6C mov ax, 0AC5h
F000:8C6F out 22h, al
F000:8C71 jcxz short $+2
F000:8C73 jcxz short $+2
F000:8C75 xchg ah, al
F000:8C77 out 23h, al
F000:8C79 jcxz short $+2
F000:8C7B jcxz short $+2
F000:8C7D mov ax, 6C6h
F000:8C80 out 22h, al
F000:8C82 jcxz short $+2
F000:8C84 jcxz short $+2
F000:8C86 xchg ah, al
F000:8C88 out 23h, al
F000:8C8A jcxz short $+2
F000:8C8C jcxz short $+2
F000:8C8E mov ax, 0CC8h
F000:8C91 out 22h, al
F000:8C93 jcxz short $+2
F000:8C95 jcxz short $+2
F000:8C97 xchg ah, al
F000:8C99 out 23h, al
F000:8C9B jcxz short $+2
F000:8C9D jcxz short $+2
F000:8C9F mov ax, 7C9h
F000:8CA2 out 22h, al
F000:8CA4 jcxz short $+2
F000:8CA6 jcxz short $+2
F000:8CA8 xchg ah, al
F000:8CAA out 23h, al
F000:8CAC jcxz short $+2
F000:8CAE jcxz short $+2
F000:8CB0 mov ax, 0CBh ; '-'
F000:8CB3 out 22h, al
F000:8CB5 jcxz short $+2
F000:8CB7 jcxz short $+2
F000:8CB9 xchg ah, al
F000:8CBB out 23h, al
F000:8CBD jcxz short $+2
F000:8CBF jcxz short $+2
F000:8CC1 mov ax, 0CCh ; '¦'
F000:8CC4 out 22h, al
F000:8CC6 jcxz short $+2
F000:8CC8 jcxz short $+2
F000:8CCA xchg ah, al
F000:8CCC out 23h, al
F000:8CCE mov ax, 0CEh ; '+'
F000:8CD1 out 22h, al
F000:8CD3 jcxz short $+2
F000:8CD5 jcxz short $+2
F000:8CD7 xchg ah, al
F000:8CD9 out 23h, al
F000:8CDB jcxz short $+2
F000:8CDD jcxz short $+2
F000:8CDF mov ax, 0CFh ; '-'
F000:8CE2 out 22h, al
F000:8CE4 jcxz short $+2
F000:8CE6 jcxz short $+2
F000:8CE8 xchg ah, al
F000:8CEA out 23h, al
F000:8CEC mov eax, cr0
F000:8CEF and eax, 9FFFFFFFh
F000:8CF5 mov cr0, eax
F000:8CF8
F000:8CF8 loc_F8CF8: ; CODE XREF: sub_F8B87:loc_F8C3Fj
F000:8CF8 jmp di
F000:8CF8 sub_F8B87 endp
Older MRBIOS:
The attachment UMC481-MR_V1.44.zip is no longer available
Reply 12 of 12, by Sphere478
Can it be enabled after boot using software?
Perhaps CHKCPU has thoughts on this.
Be sure to upload afflicted and working bioses so people can play with them.
Sphere's PCB projects.
