First post, by Harry Potter
Hi! I have and use both DOSBox and DOSBox-X. Now, I have a game for it called Boppin'. Boppin' is fun and has the option to play its in-game music without actually playing the game. The music is different than normal game music. Now, I want to play this music in the background while doing my computer work. However, when I do that, the music skips. This does not occur in the foreground, and my computer is pretty recent. I assume the emulator is not getting enough CPU time for the emulation. The game is a protected mode game, and I use the emulator's default settings. Is there a particular setting that will eliminate this?
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 1 of 3, by _Rob
set a fixed cycle count, instead of the default 'max', which will vary if the game runs in the background or foreground.
Reply 2 of 3, by Harry Potter
Thank you.
