Reply 1300 of 1539, by Kordanor
THEBaratusII wrote on 2023-05-26, 20:35:Not sure if this is the right topic to bring this up in, but I am having some trouble outputting 720x400 resolution on my Gefen […]
Not sure if this is the right topic to bring this up in, but I am having some trouble outputting 720x400 resolution on my Gefen EXT-VGA-2-DVISP.
It keeps outputting it as 640x350 instead of it's intended resolution, I've tried resetting it, switching PCs with different graphics cards and hooked it up with a monitor to no avail. I am wondering if it's anything firmware related?
I am not sure how familiar you are with that. 720x400 is basically meaning 320x200 - 720x400 is just how its handled by the monitors so to say. The correct way to handle it in terms of recording would be to capture or reduce it to 320x200 and then record it, and then scale from there. I am not familiar with the device you are using though, so I dont know which options you have.
