TNT2 Ultra faster than Geforce 2MX on Slot A?
First post, by paradigital
So, after the saga that was getting my Slot A build stable (when caps go bad), I started trying a few video cards in the machine to get a feel for what felt best/provided the best performance whilst not being too far out in terms of period. To that end I wanted to try the following:
TNT2 Ultra (Diamond Viper V770U)
Geforce 256 DDR (Creative Labs Annihilator Pro)
Geforce 2 MX (Dell OEM, not M64, 200 or 400)
Geforce 2 GTS Pro (Dell OEM)
3Dfx Voodoo 3 3000
I started with the TNT2 Ultra, which turned in a 3DMark99 Max score of 6,843.
Before diving too deep into testing a suite of games I wanted to just compare 3DM99 to whittle out the slowest, so removed all video drivers, popped the MX in and installed drivers, rebooted and ran 3DM99.
The MX turned in 5,551. Seems a bit… low.
The CPU scores between the two cards are similar enough that I think I can rule out the influence of the graphics card on the mainboard/RAM/CPU speed, with the MX scoring 14,710 and the TNT2 14,795.
The MX then proceeds to spank the TNT2 in fill rate, texturing, rasterizing, bump mapping, indeed almost every synthetic benchmark was a clear win for the MX, anywhere from 20% increase (e.g. single-pass bump mapping) to 2000% increase in single point lighting.
However, in the trilinear texturing test and the two “game” tests, the TNT2 pulls ahead. A 4% win for the TNT2 in trilinear texturing, a 15% lead in “game 1” and a 23% lead in “game 2” for the TNT2.
Something feels amiss here, the TNT2 shouldn’t be pulling off a defeat of the MX, right?
Reply 2 of 27, by paradigital
Oh don’t get me wrong, I wasn’t expecting the MX to be leagues ahead, but I wasn’t expecting it to be killed either.
I was never an MX owner back in the day, I went straight from a TNT2 Ultra to a GTS, but all the modern reviews I can find suggest that an MX or MX 400 is a good stand-in for a Geforce 256, which doesn’t get beaten by a TNT2 of any form usually.
I still feel something is amiss, the synthetic figures would suggest the MX should walk the game tests, but it doesn’t.
Reply 3 of 27, by mwdmeyer
Other than a small amount of memory bandwidth the Geforce 2 MX should be a lot quicker. In higher resolutions e.g 1024x768 I can see the TNT2 keeping up/doing better (in non T&L games), but otherwise I'm not sure why.
It would be good to test some other games.
Reply 4 of 27, by Dorunkāku
Test 'Expendable' if you want the TNT2 Ultra to look good. Test Quake III Arena if you want it to look bad.
3DMark99 runs at 640x480 in 16 bits color by default, that is not a resolution or color depth people used to game in at that time.
Reply 5 of 27, by Joseph_Joestar
Could be something simple like the GeForce 2 MX drivers having V-Sync on by default, while the TNT2 Ultra drivers had it off.
But yeah, as others have said, try some games instead of just 3D Mark. Specifically, Quake 3 in higher resolutions like 1024x768 and above, using 32-bit color depth, should show better performance on the GeForce 2 MX.
Reply 6 of 27, by paradigital
Dorunkāku wrote on 2023-05-29, 10:51:
My 3DMark99 runs default at 800x600x16, pretty sure thats not just my install.
16-bit was definitely standard affair at the time, but I tended to play at 1024x768 where I could.
Reply 9 of 27, by paradigital
Garrett W wrote on 2023-05-29, 13:28:
You haven't mentioned which drivers you used for each card. Also, are you sure the Dell OEM GF2 MX isn't using a narrower memory bus, say 64bit?
40.71 for both.
I don’t believe the Dell card is cut down, just plain jane in appearance.
Reply 10 of 27, by NostalgicAslinger
Expendable has the "Hardware Texture Compression" setting in the graphic settings, so a GeForce2 MX should run and look better than a TNT2 Ultra in this game, also all Quake 3 based engine games. The Detonator 6.31 is a good driver for the GeForce 2 series, also with less CPU overhead.
The 1999 GeForce 256 SDR NV10 was the fist nvidia Chip with hardware texture compression support.
Reply 11 of 27, by The Serpent Rider
TNT2 can't do trilinear filtering. Well, it technically can, but you'll have to drop fillrate by half or multitexturing, so Nvidia disabled that feature, just like 3dfx did. TNT family can do trilinear approximation instead, which is also called mipmap dithering. It's faster, but uglier. GeForce 2 MX can do proper trilinear filtering and will suffer considerable penalty for that.
Here's how it looks on Voodoo 5 (courtesy of ixbt.com):
97.81 KiB
TNT has similar dithering pattern.
Reply 12 of 27, by Gmlb256
Note that on Quake III, there will be color banding issues (particularly the sky) when texture compression is enabled on early GeForce cards. Forcing DXT3 format with RivaTuner can mitigate it with some performance hit.
VIA C3 Nehemiah 1.2A @ 1.46 GHz | ASUS P2-99 | 256 MB PC133 SDRAM | GeForce2 GTS 32 MB | Voodoo2 12 MB | SBLive! | AWE64 | SBPro2 | GUS
Reply 13 of 27, by SPBHM
paradigital wrote on 2023-05-29, 16:09:
40.71 for both.
does it have 8 memory chips or just 4?
Reply 16 of 27, by imi
I upgraded from a TNT 2 ultra to a GF2 MX 200 MX 400 back in the day and it definitely was a considerable upgrade... I remember how happy I was that a cheap card like that gave me a boost.
Reply 18 of 27, by leileilol
Gmlb256 wrote on 2023-05-29, 17:28:
IIRC that was fixed around detonator 12.41. Quake3 tells OpenGL to load RGB textures in a S3TC format and nVidia's on-demand compression wasn't great. Note that Q3 lacks compressed textures to begin with so it's a quality loss to enable texture compression anyway (it's default on for Savages in mind with the hopes that no other vendor does it).
This, of course, has fed a few "3dFx Rulez!!!! VooDoo III > GForce 2!!! FUCK 32BIT SCAM" on the internet, where arguments for not supporting a feature equals better hardware.
Reply 19 of 27, by imi
mwdmeyer wrote on 2023-05-30, 03:23:
Oh no the MX 200 would not be an upgraded at all, a lot less memory bandwidth, only case it would be if you had a very slow CPU and low res.
maybe I'm misremembering things, but I thought it was a MX200, it was an ASUS V7100 and apparently that doesn't say much as there's been different versions.
...ok I looked into it more, apparently it was an "Asus V7100PRO/64M", so MX 400, sorry about that ^^
