YMF724 XP driver issues
First post, by G40
I've been pulling my hair out (what's left of it) trying to get FM sound via MIDI working on my XP P4 machine. Couldn't get my trusty ESS solo 1 working last night (Re: Help installing ESS Solo 1 in XP), but by a stroke of luck, an eBay purchase YMF-724 equipped card arrived in the post this morning.
I stuck it in, booted up, and it worked right away! FM synth showed up as a MIDI device and worked in my favourite MIDI sequencer. Amazing!
Then I thought I'd be clever and install the "proper" driver. This worked, in as much as it replaced the FM synth with with the XG wavetable synth as the MIDI device. 🙁 In an ideal world I'd like to be able to access both, but here and now I need access to FM voices via MIDI.
Tried installing PowerYMF, which seemed happy, but still no sign of FM.
Uninstalled both, rebooted, XP wanted to connect to the internet to install drivers (machine is offline), failed to install. Pulled card. Rebooted. Turned off, reinstalled and booted up, same again. Put the Windows CD in but it couldn't find drivers. Tried selecting it manually from a list but couldn't find it.
I'm kicking myself because it sounded great (in a weedy lo-fi way) for about 5 minutes.
Any idea how I can either roll back to the standard XP driver which worked fine for FM or even better find a driver which allows access to both MIDI synths?
Reply 1 of 6, by G40
Just had another look following finding this post [YAMAHA YMF724] OPL3 features support on Windows XP, impossible?
I have enabled legacy mode, and unlike the poster there, successfully installed the new legacy device, but the FM synth still isn't available as a MIDI device.
I'm kicking myself for trying to improve on the standard XP driver (which has now disappeared), it appears I have system restore turned off too so that's not an option.
Reply 3 of 6, by G40
Just thought I'd ask to see if anyone's managet to get FM and XG MIDI working at the same time - in any OS. It would be nice!
Reply 4 of 6, by Joseph_Joestar
G40 wrote on 2023-07-17, 14:28:
Both XG and FM synth work fine under Win98SE using the stock Yamaha 1040 drivers. You can find those on Phil's website. Specifically, you want this file:
yamaha_dsxg_driver_win_95_98_me_v._4.07.1040__directx7_certified_.exe
In the past, I used one of these YMF7x4 cards for DOS gaming, and it was really nice to have both options available.
Reply 5 of 6, by G40
Joseph_Joestar wrote on 2023-07-17, 14:43:
Both XG and FM synth work fine under Win98SE using the stock Yamaha 1040 drivers. You can find those on Phil's website. Specific […]
Useful info, thanks.
Reply 6 of 6, by SilverMiner
I've got a card with a chip named YMF724F-V. In WinXP it's detected as PCI\VEN_0073&DEV_000D&SUBSYS_000D0073&REV_03\4&72ACDAA&0&4820
As I guess from the drivers I've found, the Vendor ID should be 1073, but my card has 0073 and it may be related to that none of the drivers that I 'successfully installed' work
The Boggy Region megawad released: https://www.doomworld.com/idgames/?id=19210
The Boggy Region 2 megawad released: https://www.doomworld.com/idgames/?id=21748 (for ZDoom 2.8.1)
