First post, by DosFreak
http://forums.steampowered.com/forums/showthr … ighlight=dosbox
Any experienced DosBox user would know that Auto only works for protected mode games which obviously (well obvious to experienced DOS gamers) Wolf3d is not.
People are interpreting this behavior as a "bug", when it's actually a "feature".
Is there any way to fix this? I think I remember along time ago suggesting putting if a game uses real/protected mode in the titlebar or in the console but I 'm not sure.
Make your games work offline
Reply 1 of 22, by wd
Rank DOSBox Author
DOSBox Author
No, dumb users can't be fixed.
Reply 2 of 22, by franpa
is holloween harry a protected mode game? is monster bash a protected mode game? they dont run that well @ 3000 cycles which is what AUTO sets the cycles to.
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 3 of 22, by red_avatar
It's why I ALWAYS change auto to max for default - it's far more reliable and for the games that are sensitive to speed, auto is not garanteed to work anyway.
Reply 4 of 22, by gulikoza
The problem is that with max, dosbox will consume 95% cpu even at prompt. Plus some games (like prince of persia) will be broken or run too fast. Unfortunately not everything can be autodetected...
http://www.si-gamer.net/gulikoza
Reply 5 of 22, by wd
Rank DOSBox Author
DOSBox Author
And some games don't work at all, like monkey1 and several others.
So you'd need another (additional), as simple-as-possible check to divide
the game types into more classes.
Reply 6 of 22, by franpa
or include a additional warning message when starting DOSBox with the MAX cycles setting active?
my website
Reply 7 of 22, by wd
Rank DOSBox Author
DOSBox Author
Doubt that anybody reads it... maybe somebody can make a list of games
that don't work with something like say "cycles=max 60%" or so, on a not
too slow pc.
Reply 8 of 22, by Zup
What is the "protected mode" criteria? I mean, what triggers "protected mode" and what (if something at all) changes back to "standard mode"?
I remember reading about "flat mode" (enabling protected mode, changing segment length to 4Gb and then disabling protected mode to manage 4Gb with standard mode). Will that count as "protected" or "standard" mode?
I'm selling some stuff!
Reply 9 of 22, by wd
Rank DOSBox Author
DOSBox Author
Flat mode is very very rare, think ultima7 being the only relevant one.
If a game switches to pmode and cycles=auto, dosbox switches to max
cycles for the duration of the game (ie. returns to the old [fixed] cycle
value when the game exits, int21/4c).
Reply 10 of 22, by `Moe`
Could Comanche be flat mode as well? It had the same memory manager probles as Ultima 7, requiring none at all, or VCPI.
Reply 11 of 22, by wd
Rank DOSBox Author
DOSBox Author
Doubt it, more likely they want cpl0 and thus prefer no memory manager
at all or vcpi (which should run at cpl0, too), but don't have that game.
Reply 12 of 22, by kekko
Since there are many things that can't be autodetected in any way, we need a way to make the configurable options more accessible to the novice users, that's why dosbox definitely needs a menu or at least a gui similar to the keymapper (think of pressing ctrl+f2 and it shows up the options menu).
my two cents...
Reply 13 of 22, by wd
Rank DOSBox Author
DOSBox Author
Moe was working on this some time ago.
Reply 14 of 22, by `Moe`
It's not dead yet, but still sleeping. Every time I continue working on it, I can't figure something out and let it be. Shame on that, since the GUI toolkit itself is already fully working.
EDIT: I began working on it again, and this time I got real progress. Maybe there will be a beta version soon, although I guess it will still be quite some time before it becomes available for the general public.
Reply 15 of 22, by butterfly
Listen, when something doesn't work with auto I just change it to max. It doesn't look that difficult to me and if some game or program doesn't work at all then peace!
Reply 16 of 22, by Og
Pardon my ignorance, but where exactly IS it written that 'auto' sets 'max' only for protected mode games?
Reply 17 of 22, by wd
Rank DOSBox Author
DOSBox Author
nowhere
Reply 18 of 22, by Og
Well, then why are you calling a person that doesn't know this "dumb" ? 😖
Reply 19 of 22, by wd
Rank DOSBox Author
DOSBox Author
Maybe reread this thread and the original thread before posting.
Dunno what you want.
