First post, by Kekkula
Hello.
So I'm trying to get large dd disk image working with my xt and gotek.
I watched this video where Adrian gets it working with tandy and HXC.
https://www.youtube.com/watch?v=Lw0JV4TypSo
I was thinking this should be possible also with Flashfloppy... maybe.
Problem I'm having is that I can't get Flashfloppy to recognize the image I made with Hxctools. The image works with dosbox.
I don't understand how Flashfloppy img.cfg file works. I copied default file to root of the usb and 360k and 720k files work, but when I select my 2,5Mb file I get error 31.
I tried to add these lines to end of the img.cfg file.
# eob test
[eob::2611200] # <- the file I'm trying to mount is eob.img
cyls = 255
heads = 2
secs = 10
bps = 512
rpm = 300
Reply 1 of 2, by Kekkula
Got it working after changing file format from .img to .hfe
Now problem is I can't find BIOSPTCH.SYS , so I can't use any programs from image.
Reply 2 of 2, by jtchip
Kekkula wrote on 2023-06-08, 14:53:
# eob test
Good that you got it working but from the documentation the name matches *.<tag>.{img,ima,dsk} so in this case the filename should be <name>.eob.img.
