First post, by kahuna
- Member
Hey Vogsphere people!
I could use some help.
I'm building yet another retro PC, it has the following specs:
- Asus p8p67-m microATX motherboard
- Intel i5 2500k Sandy Bridge
- 16GB of DDR3 RAM
- Nvidia Quadro M6000 12GB
- Crucial MX500 SSD (Windows XP) - connected to the 6Gbps SATA-1 port on the motherboard
- Silicon Power SSD 128GB (Debian GNU/Linux) - connected to the 6Gbps SATA-2 port on the motherboard
I was able to install Windows XP configuring the SATA ports in IDE mode in the BIOS. I have installed the WXP Intel drivers manually, and also using the "Snappy Driver Installer" tool.
Problem is, when I flip the switch and configure the SATA ports in AHCI mode, I get a blue screen that I cannot even read as the PC just reboots itself really quick.
Booting into the Linux kernel, I can see the SSD drives are connected to:
SATA Controller: Intel Corporation 6 Series/C200 series chipset family 6 port Desktop SATA AHCI controller (rev 05) [AHCI 1.0]
By the way, Debian works in both IDE and AHCI mode.
I couldn't find appropriate drivers I can put in a floppy drive to use them during the WXP installation ("hit F6..." prompt), so I can avoid IDE even during WXP set up.
Also, I've got a SATA PCIe card based on the Marvell 88SE9215 chipset. It works great, it has drivers for XP and I can boot from it.
Problem is, this microATX board only has 1 PCI slot and 1 PCIe slot I can use. I'm trying to find a X-Fi Sound Blaster in good shape. Using this PCIe SATA controller will be limiting me. So, I was hoping I could configure the SATA ports on the motherboard in AHCI mode and make them work in XP.
Any comments, recommendations, guidance will be really appreciated.
Thanks!
Be free!
