First post, by stalk3r
Does anyone have this kind of card? I am looking for its jumper settings, but the only thing I found is that it was made by Protac: https://fccid.io/J4UVGA415BFT4
Reply 1 of 13, by derSammler
J9 is for 8-bit mode (all closed = 8 bit, all open = 16 bit). No idea about the rest, there's normally not that much on a VGA card you need to configure.
Reply 2 of 13, by stalk3r
I suspect this has a jumper for WS 0/1 , but way too much combinations there
Reply 5 of 13, by Rawit
I see J2 on your board but without pins. So it's not unfeasable to short it to get Zero WS enabled. I actually thought wait states were more a VLB thing.
YouTube
Reply 6 of 13, by SirNickity
No, ISA mandates a default wait-state timer that can be overridden if the card is fast enough. In case others are lurking and aren't aware, most Trident boards I've seen adhere to a reference design WRT the jumpers, so the list above will apply to a lot of different cards.
Reply 8 of 13, by stalk3r
Tiido wrote:
I got a significant boost on my 8900D by enabling 0WS and FIFO.
I have tested this quickly with a 8900CL-B (similar to 8900D in terms of performance) which has a soldered jumper for WS:
Vidspeed WS1 - 3869
Vidspeed WS0 - 5140
(32% increase)
LM60 WS1 - 3870
LM60 WS0 - 5120
(32% increase)
3DBench WS1 - 15.8
3DBench WS0 - 15.1
(4.6% increase)
It gives a boost indeed.
Reply 9 of 13, by keropi
I have tried 5424 and 5429 isa vga cards that have the 0ws jumper - it never worked reliably for me... Benchmarks were ok but games or win3 would just crash... The boost is indeed considerable if the system is stable
Reply 10 of 13, by stalk3r
I ran Doom timedemo several times with 0ws on the Trident, not a single crash. Haven't tried win3.1 though
Reply 11 of 13, by SirNickity
So, it runs normally then? 😉
Reply 12 of 13, by Jo22
Yup. And in three (3) different ways, too!
- That's why 3.1 came out so quickly. 😁
If Win3 was a game, each type would correspond to a difficulty level. 😉
Enhanced = HARD
Standard = Normal
Real = Easy
Reply 13 of 13, by GunKneeNeon
stalk3r wrote on 2019-08-06, 12:19:
I have tested this quickly with a 8900CL-B (similar to 8900D in terms of performance) which has a soldered jumper for WS: […]
Vidspeed WS1 - 3869
Vidspeed WS0 - 5140
(32% increase)
LM60 WS1 - 3870
LM60 WS0 - 5120
(32% increase)
3DBench WS1 - 15.8
3DBench WS0 - 15.1
(4.6% increase)
I have a TVGA 9000C with FIFO and ZeroWS enabled. Have been tested with Vidspeed before and after enabling 0WS. The result showed a 21% boost (640x480-256):
Vidspeed WS1 - 2767
Vidspeed WS0 - 3352
BTW, I soldered a jumper to J5. There seemed to be no difference if I shorted them. By examining the PCB myself, it seems to be Memory Clock Frequency related. Anyone knows what it does actually?
The attachment j5.JPG is no longer available
Constantly looking for the driver for Acer Magic v1 MPEG decoding card.
