Abit BP6 issue
First post, by oldgames79
I’m trying to fix a abit bp6 that doesn’t light up and I partially found the source of the problem.
There is a regulator AMS1117 that is short circuit on pin 1 and 2 => the Vout is connect to the ground.
There is also the EC30 in short circuit. How to find the component that was in short circuit ?
The AMS1117 has been desoldered and tested without short circuit idem the for EC30.
Thanks
Edit:
After few seconds, the motherboard tries to light up but without success...
Reply 1 of 15, by Karbist
Is this regulator on the 5v standby coming from psu?
is pin 2 dead short to the ground like zero ohm or it's more than zero ohm like 5 ohms or more?
Reply 2 of 15, by rasz_pl
multimeter with good range and going over all chips powered from 3.3V measuring VCC to VDD in resistance mode as close to those chips as possible. With any luck you will get the idea where resistance is lowest.
Another option thermal camera and injecting voltage on 3.3V rail slowly going up and looking whats going warm, again with luck you might get by with a finger instead of camera
Reply 3 of 15, by oldgames79
Karbist wrote on 2023-06-13, 20:33:
Yes it's the 5V stanbdby coming from the PSU.
Computer off I have 5V on Vcc and I have 2,6V on Vout (normally I should have 3.3V ?) and the AMS1117 is very hot. On the ground I have a 0 ohm (R126).
Reply 4 of 15, by oldgames79
rasz_pl wrote on 2023-06-13, 21:37:
Computer off the AMS1117 is very hot. I’ll check on the other chipset
Reply 5 of 15, by Karbist
that standby 3.3v goes directly to the south bridge chipset, put the ams1117 back in the board and put your finger on the south bridge chipset, if one spot on the chip gets hots, it's dead.
Reply 6 of 15, by oldgames79
Karbist wrote on 2023-06-14, 06:22:
The southbridge is the chipset between the PCI port and the battery ?
Reply 7 of 15, by Karbist
Yes.
The attachment ab-bp6.jpg is no longer available
Reply 9 of 15, by Karbist
well check the other chips like the I/O chip on top of pci slots. you can also put your hand on the back of the board and feel what area is getting warm.
Reply 10 of 15, by paradigital
Another alternative to thermal camera or “finger” is the “drench with isopropyl alcohol and watch which component evaporates the liquid fastest” method.
Either way, injecting voltage onto the suspected shorted rail is likely the simplest solution to finding the short without access to schematics and/or boardviews.
Reply 11 of 15, by oldgames79
Karbist wrote on 2023-06-14, 15:32:
Finaly the southbridge is very hot 😒
I will try to replace the chipset...
Thanks
Reply 12 of 15, by rasz_pl
replacing this kind of chip is more expensive than sourcing another board
Reply 13 of 15, by oldgames79
rasz_pl wrote on 2023-06-14, 16:15:
On ebay it's 250€ for a new motherboard VS 10€ for a new chipset.
If you have a BP6 in stock I’m interested 😉
Reply 14 of 15, by rasz_pl
oldgames79 wrote on 2023-06-14, 18:12:
$80 2 months ago https://allegro.pl/oferta/plyta-abit-bp6-2x-p … tas-13598394244
its not the chip cost, but bga rework that might make it uneconomical
Reply 15 of 15, by oldgames79
rasz_pl wrote on 2023-06-14, 18:17:
Argh too late
Thanks for your help
