First post, by MarkTheMorose
It's probably heresy to admit it, but I removed all the caps from a working (as far as I knew at the time) motherboard, for de-soldering practise. (I needed to replace one on a monitor). In my defence, probably none of us knew at the time just how sought-after some 'old hardware' might become.
Anyway, I wonder if there is any reference anywhere that describes what value caps go where in one of these motherboards.
Thanks,
Mark.
Reply 2 of 8, by PC Hoarder Patrol
MarkTheMorose wrote on 2023-06-11, 12:01:
It's probably heresy to admit it, but I removed all the caps from a working (as far as I knew at the time) motherboard, for de-s […]
Thanks,
Mark.
I have this board somewhere - its a revision 2 - (likely buried under a pile of other stuff 🙁 ) ...if no-one has pitched in the answer in a day or so, I'll dig it out and draw up a cap map for you.
Reply 3 of 8, by Pino
I also have a v 2.0 on my main retro machine, it's only about 15 capacitors, so I would be glad to help if you confirm your board is the same revision.
Reply 4 of 8, by PC Hoarder Patrol
Thanks,
Mark.
Apart from the 3 highlighted in the attached pic, all other caps are NRSY 1000uF 10v 105C
Note that revision 1.x boards seem to have slightly more caps (and possibly different values)
Reply 6 of 8, by MarkTheMorose
Thank you very much PC Hoarder Patrol; this exactly matches my revision 2.0 board, which I just found while looking for something else, of course. It's now evident that I'd removed the Slot 1 CPU retention bracket, I might have one around. It's not something I'll be refurbishing any time soon.
Thanks again,
Mark.
Reply 7 of 8, by MarkTheMorose
Pino wrote on 2023-06-12, 15:42:
Hi Pino, if the roster of caps on your board is any different to that supplied by PC Hoarder Patrol, I'd appreciate a list, otherwise I'm good.
Thanks,
Mark.
Reply 8 of 8, by Pino
Yes, my board have the same capacitor values.
Good luck repairing your board, it doesn't have a lot of fancy BIOS options, but it's rock solid, great slot 1 board.
