First post, by CADuke
I have intact Compudyne PT66W-33. It has an Acer V10 motherboard. I came across an FTP listing on the acer.de site showing manual, bios, and jumper settings on the Wayback. I can no longer find the page. I do not see any files on archive.org's FTP collection for the V10. I was wondering if anyone had the full manual from German FTP?
Current Resources:
https://theretroweb.com/motherboards/s/acer-v10
http://www.uktsupport.co.uk/acer/mb/v10.htm
https://stason.org/TULARC/pc/motherboards/A/A … 10-PROJECT.html
https://stason.org/TULARC/pc/motherboards/A/A … -ALL-IN-ON.html
https://web.archive.org/web/19980201191745/ht … chInfo/bios.htm
I have come across a few links from other posts and forums with links that work in Wayback Machine, but offer no additional info from the above sites.
Reply 1 of 2, by PC Hoarder Patrol
CADuke wrote on 2023-06-18, 07:00:
I have intact Compudyne PT66W-33. It has an Acer V10 motherboard. I came across an FTP listing on the acer.de site showing manua […]
Current Resources:
May already have seen, so not much to add really 🙁 ...there is an html-based ftp directory browser on acer.de which has subs for bios, jumpers & manual though only bios has any further page content https://web.archive.org/web/20010423085247/ht … &ftpdir=/pc/v10
According to @easy_john Re: Bought these (retro) hardware today the board is also used in the Lucent Intuity MAP/5 https://www.manualslib.com/manual/2054251/Bel … p-5.html#manual , though really a system rather than a board manual.
The attachment Acer-V10_easy_john.jpg is no longer available
Reply 2 of 2, by CADuke
PC Hoarder Patrol wrote on 2023-06-18, 12:10:
May already have seen, so not much to add really :( ...there is an html-based ftp directory browser on acer.de which has subs f […]
Current Resources:
Thank you, I came across the HTML directory and couldn't find it again. Looks like no manual or jumper settings. The Lucent Tech looks similar to other Compudyne models with V10. So I am guessing the model I have is either likely one of AcerPower SV/V/DV models. It is kind of weird that LT Intuity Map 5 seems to be the only system manual.
