CPU clock LED
First post, by uebersoldat
I recently picked up one of those coveted Taiwanese AT clone cases we all had back in the late 80's and early 90's but it's missing the CPU clock LED that usually mounts next to the turbo button.
I can't seem to find a part for that so I was looking to build one from some kind of generic two-digit LED and wire it up similar to this guy's thread - CPU Clock Speed Diplay
Any help or tips would be greatly appreciated! I'd love to complete this look and I've been searching for a case like this for a long time and this is the first one semi-affordable I was able to get hold of.
Reply 2 of 5, by uebersoldat
wiretap wrote on 2023-06-22, 20:28:
You can find them on ebay sometimes. I purchased a few from there.
Alternatively, feel free to modify/build one of these: https://github.com/wiretap-retro/2-digit-Turbo-Display
I have a few different variants in my Github repo. ----^
Thank you a million! What search terms do you use for eBay to find em?
Reply 3 of 5, by rasz_pl
You can reprogram one of those cheap Chinese STM8S based products https://github.com/TG9541/stm8ef like:
$2.5 free shipping thermostat https://github.com/TG9541/stm8ef/wiki/Board-W1209 big pcb makes this kinda ackward to mount
~$4 W1209WK dual 3 digit display https://github.com/TG9541/stm8ef/wiki/Board-W1209WK you could reprogram this to display cpu temperature on one lcd and MHz on the other 😀
~$2 my absolute favorite, voltage meter https://hackaday.io/project/16097-eforth-for- … other-voltmeter hard to buy the right one, most $1-2 voltage meter modules on ebay use dedicated measuring chip nowadays, but there are still STM8 based ones available, for example https://www.ebay.com/itm/174081875242
of course this requires some programming and soldering skills, or motivation to learn
Edit: Just realized you already have case with a specific hole 😀 forget the above.
I looked at https://github.com/wiretap-retro/2-digit-Turbo-Display and while it is using ridiculously cheap and easy to program ATtiny85 its also complicated because of it, not enough pins means its also using two SN74HC595DR shift registers so cant replicate using off the shelf dev board, need this exact pcb manufactured.
Instead https://microdigisoft.com/2-digit-7-segment-d … h-arduino-nano/ https://www.instructables.com/Arduino-Nano-LED-Display/ Arduino Nano is $2, dual 7-segment display will also be $1-2, you need to measure your hole to get the appropriate size one.
Reply 4 of 5, by wiretap
uebersoldat wrote on 2023-06-22, 22:00:
MHz Display, search in the electronics/computers section. They come up every so often. Right now I only see two at a ripoff price.
My Github
Circuit Board Repair Manuals
Reply 5 of 5, by uebersoldat
Thank you all very much for the information. Looks like I have a lot to dig in to! Looks like I'll be building one somehow so I'll update this thread with progress. Should be fun!
