Reply 49620 of 57738, by Bancho
Picked up this Reveal WAVEExtreme 32 Sound Card
Reply 49621 of 57738, by PC Hoarder Patrol
schmatzler wrote on 2023-06-22, 14:48:
Yes, that information is outdated. The X7460 CPUs are supported by the Intel 7300 "Clarksboro" chipset, which this board has. Cl […]
H3nrik V! wrote on 2023-06-22, 14:15:
I can only see information that this board supports up to quad cores? But that may be not updated info?
Clarksboro is a requirement for using these CPUs and the only chipset they can run on, officially.
You can find this information on the archived Intel website and here on cpu-upgrade.
Intel removed the "Compatible products" section from their current website for some reason.
There is still a small possibility that the BIOS doesn't support them (Supermicro never released an update for it, there is only one version).
If that is the case, I will be very disappointed.
Rest easy 😀 https://www.supermicro.com/support/faqs/faq.cfm?faq=9206
Reply 49622 of 57738, by Law212
Some really nice person saw me make a post about old hardware and he messaged me to tell me he had this old card and asked if I wanted it. I said OK and he ended up shipping it to me at no cost to myself > Then I found out he was shipping from Denmark and I said it was too expensive and I'd pay for shipping. He still refused.
Here is what he sent.
Reply 49623 of 57738, by BitWrangler
Awesome freebies, what a nice thing to happen (*flips out list of countries to test death ray on, crosses out Denmark* 🤣 )
Reply 49624 of 57738, by gerry
Law212 wrote on 2023-06-23, 14:05:
nice workhorse cards plus edibles! that is a nice person indeed! 😀
Reply 49625 of 57738, by schmatzler
PC Hoarder Patrol wrote on 2023-06-23, 11:50:
Nice! I looked for other FAQ entries on that page and found hints to later beta BIOS releases for the X7QC3.
So I just asked the Supermicro support and they sent me the last one they made.
It's from June 2016, while revision 1.0 is from 2008. They supported this board for a long time.
Attaching both BIOSes here. I will also upload them to theretroweb later.
Reply 49626 of 57738, by acl
Some really nice person saw me make a post about old hardware and he messaged me to tell me he had this old card and asked if I […]
Really a nice person for sure.
This remindes me of a computer i may write about here.. if I found time to.
About two decades ago i found a french 8bit computer in the trash. Thomson TO9 from 1985.
Unfortunately an important part was missing : optical pen. This computer uses a an optical pen for navigation in the GUI. I asked for info in a forum and a member shipped me two replacement optical pens for free. These parts would probably have been unobtainium anywhere online, because of the age of the computer and by the fact it is not as widespread as apple/commodore/ZX81/... systems.
Some time later, two caps exploded while I was using it and I stored it for more than a decade. I repaired it 6 month ago and it's now fully functional.
Maybe i could write about it in the "system specs" section. Even if it's not a PC.
Reply 49627 of 57738, by Mandrew
I can't resist 'extreme' for some reason, even if it's just a Core2.
Reply 49628 of 57738, by Ricimer
Thermalwrong wrote on 2023-06-22, 23:11:
Wow, what are you doing for CPU cooling? Will it fit many ATX cases?
Currently it has two passive heatsinks, but I'm going to try and add some low noise 60mm fans (the fan headers are only rated at 80mA). I finished a passive dual P3 recently, but the heatsinks on those are double slot height and the Coppermines are half the PPro wattage.
For a case I'm thinking about the Phanteks Enthoo Pro, it has all the standoffs and space for the board. There is also the Fractal Define 2 XL (the 7 is 2mm too small), but I like the Gotek with the rotary dial that sticks out, so a door might not work.
Skalabala wrote on 2023-06-23, 01:13:
Wow thats awesome! But you need two black CPUs for that 1Gb of ram 😜
Are you going to try VOODOO 2 SLi in it?
I thought about the 1MB cpus, but not sure about VRM and PSU capacity. I will use a Corsair RM850 I already have and it has 150w on 3.3/5v.
Using it with a Quadro4 NVS 100, not the right era but cheap and I don't have a retro monitor. Viewing everything through a Datapath visionrgb at the moment, so dvi/vga out was what I wanted (and low power!).
Reply 49629 of 57738, by HanSolo
Got an untested IBM 760ED notebook for little money. That's the one with the flip-up-keyboard.
Unfortunately it doesn't show any signs of life 🙁 So I'll probably sell it again for parts.
Reply 49630 of 57738, by ediflorianUS
HanSolo wrote on 2023-06-25, 16:46:
hi. How much for the IBM 760ED? do you need assistance in trying to fix it?
My 80486-S i66 Project
Reply 49631 of 57738, by Thermalwrong
Pull out the expansion RAM board which you can get to from the slide off cover underneath, that's caused real problems on my Thinkpad 760EL - still can't get that working properly in fact. But it works okay without it.
The Thinkpad 760 series outputs some POST code information through the parallel port, if you've got a reader for that.
Also there's a NIMH battery hiding inside the keyboard part under the palm-rest plastic, which usually damages traces in the area.
Reply 49632 of 57738, by BitWrangler
Just saw a IBM FRU 29H9296 on eBay when I'm trying to see what the module looked like, trying to ID a couple of weird ones I got the other week.
Reply 49633 of 57738, by ODwilly
Well it started out as not retro. But bought a cheap GTX 1060 6gb and came home with this when I commented "Cool XPS" and the response from the seller was "want to take it"?
Dell XPS 730x H2C w/ i7-940, 2 500gb WD drives, a 8gb? Stick of Crucial Ballistic Elite 1866mhz, and a corrupt original A 1.0.0 bios that had issues until I disconnected all the front panel USB cables and updated the bios to the last offical 1.0.5 bios
Next up is maybe a Xeon swap and an Alienware Area 51 A11 bios upgrade
Reply 49634 of 57738, by Pierre32
Guillemot Maxi Studio ISIS. It came with the daughterboard for the breakout box, but not the box itself. Which is fine - it came up cheap and I was keen just to grab it for the Dream chip.
The attachment Guillemot Maxi Studio ISIS.jpg is no longer available
Reply 49635 of 57738, by appiah4
Pierre32 wrote on 2023-06-26, 07:12:
Awesome MIDI card, but IIRC ESS Maestro lacks a hardware FM Synth. I'd have loved to score one as well, enjoy!
Reply 49636 of 57738, by keropi
nice one
I had 2 of these and both had detection issues , meaning the driver would not always detect the ESS chip and failed to load rendering the card useless
after random reboots it might work... tried 3~4 of different systems and always got this issue - no idea why
when it works it is nice though
Reply 49637 of 57738, by HanSolo
Thermalwrong wrote on 2023-06-25, 17:33:
Pull out the expansion RAM board which you can get to from the slide off cover underneath, that's caused real problems on my Thi […]
ediflorianUS wrote on 2023-06-25, 17:18:
Thanks for the suggestions. Pulling out the RAM board, CD and HD drive and main battery didn't change anything.
What I think is strange is that it shows absolutely NO sign of life. I think next I'll try to measure the power supply (have to find the pinout first since it has 4 pins).
Then I'll take a look at the other battery.
Reply 49638 of 57738, by appiah4
I finally have a working VIA C3 CPU. I also have a decent mATX Socket 370 board with ISA to go with it.. Time to but together a reverse sleeper mATX build 😁
Reply 49639 of 57738, by HanJammer
This rare graphics card. Apparently it's high res monochrome card which came with vertical monochrome monitor (which I don't have). Still super interesting piece of hardware for a price I paid.
