Reply 24540 of 31480, by TheAbandonwareGuy
- Oldbie
luckybob wrote on 2023-06-23, 17:53:TheAbandonwareGuy wrote on 2023-06-23, 17:35:A P2 450 running at 266MHZ would perform identically to the real 266MHz part correct? EDIT Nope: The 450 is a 100mhz Deschutes part, so I need to order a Klamath P2
close enough. as i recall, you can underclock just about any p2/p3 to a lower fsb.
I ended up ordering a replace SL2HE 266mhz. I want to keep this machine similar to its factory configuration, as I'm quite fond of it.
Wonder what caused the CPU to fail like that though. Is the base memory failing a known issue with certain P2s or did I just lose the silicon lottery here? This CPU was never really abused. Ran it at stock clock speeds, had the factory heatsink with thermal sensor on it, etc.
