Grzyb wrote on 2023-06-28, 14:38:No need to run own GSM network.
The original GSM standard (2G) is still supported by modern cellular networks.
Currently, operat […]
Currently, operators are about to disable 3G support, and safe bet they will also disable 4G when 5G dominates the market.
But I don't think there are any plans to disable 2G - there's plenty of specialized devices that only support 2G.
They are definitely talking about shutting down 2G in France but there are a lot of issues because some critical systems works over 2G.
Like emergency buttons in elevators and some infrastructure equipments (water or energy distribution, remotely controlled/monitored through old 2G systems)
By the meantime, you can probably still use 2G PCMCIA modem cards to play Doom on the go.
I don't think there is any use for landline dialup analog modems. (So i don't keep them)
You can use a Cisco analog to VOIP converter to connect two modems. But these devices are not really cheap.
Cathode Ray Dude did a video about that : https://www.youtube.com/watch?v=EGFIEF6siIE (+ A tutorial on his website : https://gekk.info/articles/ata-config.html )
Two modems can't be connected directly because key parts of the dial process are handled by the telephone network and not by the modems.
I'm not a telephone engineer but i suppose that the two modems also can't negotiate the analog modulation details by themselves.
The noise heard after dialing on an analog modem is actually a handshake/negociation for the analog protocol to be used.
Anyway, using serial null modem cable is much easier.
Raw serial for HyperTerminal/XMODEM/ZMODEM.... or for games that supports it (Doom, Diablo, ...)
Or, if you need IP, you can use PPP over the serial link
I've used that several time at home : Retro Laptop W95 -> Null modem cable -> USB serial adapter -> RaspberryPi (PPP server + routing) -> Home Network/Internet.
Enjoy you home 1Gbps fiber optics over a 9600baud serial link !
