Reply 40 of 50, by kasfruit
I don't quite understand the dictatorship in this forum
I didn't share any link I just told @Sphere478 the way to find the software utility he was looking for.
I can't PM you (more censorship) but maybe you can PM me.
Reply 41 of 50, by DosFreak
It's not very hard. Don't mention or post links to such software if you don't agree then don't use these forums.
Windows XP is not free to download just because you think it should be.
Make your games work offline
Reply 42 of 50, by LSS10999
kasfruit wrote on 2023-06-28, 16:28:
It's difficult to say. I should have pointed out that you should avoid mentioning things like those in this forum, the brief moment I read the now-deleted posts.
Personally I had got myself into hot water several times because of the problems around those things in some other forums, and that was a long time ago.
There are better places to discuss about those, just not here. And plus, for these things, Google will NOT help you. Use some other tools like DuckDuckGo.
Reply 43 of 50, by kasfruit
DosFreak wrote on 2023-06-28, 19:10:
LOOOL go tell that to archive.org and other webs that host genuine ISO's
Reply 44 of 50, by kasfruit
LSS10999 wrote on 2023-06-29, 00:37:
no thanks, that Duckshit is not meant for me.
the discussion was about Paragon GPT loader and I shared a possible source for download (without links)
I don't use it myself but it may be useful for others that are XP fans like me or that got into trouble with the WS2003 system files
Reply 45 of 50, by ediflorianUS
I know this is not probably the best topic , but how do I re-do/rebuild the data tree on a broken partition on a 1 TB drive? (it see's the partition under T.d. for example, and I can access there) but it won't save the file-format so I can access from a normal explorer....
BTW , for NAS I am using a cheap ZyXEL NSA310S , it works fine with evrything , even broken sata disks.(saved me a few unformatable disks).
My 80486-S i66 Project
Reply 46 of 50, by slowmf
Question: is it better to have a drive strictly for gaming or okay for the OS and games to be in same drive? I plan to run a 2tb ssd with no partition.
Reply 47 of 50, by LSS10999
slowmf wrote on 2023-07-05, 02:11:
I don't think this is the right place to discuss this. This thread is more about getting GPT disks working properly on XP. Formal GPT disk support only came to be since Windows 2003, though not for booting, and probably still limited to 2TB or less.
Still, I don't think there is any noticeable difference for SSDs with OS and games being on the same drive or different ones. Most systems only ship with a single drive after all.
EDIT: I'm making this edit to avoid double-posting.
kasfruit wrote on 2023-06-29, 02:04:
I did manage to find someone who uploaded the Paragon GPT loader to the Internet Archive. You should be able to easily find it via DuckDuckGo search.
It appears Paragon GPT loader, at least the officially released versions, had serious issues with accessing files located above 2TB. More contexts about the issues can be found here and here.
Haven't tested it, but according to the one who uploaded it to the archive, despite using the patched driver, Windows may not boot if more than 2TB data is written to the disk. Not sure what exactly the issue was, but in overall using disks larger than 2TB with XP is not a good idea regardless of which option you use (be it GPT loader or Win2K3's files).
DuckDuckGo is indeed inferior when it comes to mainstream stuffs. If you want to search mainstream stuffs and privacy is not a concern for your search context then stay with Google for those.
It is certainly useful, however, if your search topic involves something sensitive, especially when it comes to things that would run into dee-emm-*censored*-A.
Reply 48 of 50, by kasfruit
Has anyone got a large HDD with 4Kn sectors ?
they are mostly enterprise disks https://www.westerndigital.com/products/inter … hdd?sku=0B36400
I know that some external enclosues may turn any disk into a 4kn one but I don't actually know which ones for a fact
I really want to know if XP would be able to format them without using this unreliable GPT patch
Reply 49 of 50, by LarryM
Why GPT ?
You can expand your MBR (SATA) Drive (at least) to 4 TB with ease.
I use winXP SP3 32-bit (primary) and GPT makes a lot of problems.
https://care.acronis.com/s/article/38937-True … jk0&ckattempt=1
Symptoms
An operation attempt with a drive larger than 2 TB fails with following error:
Please install Virtual Disk driver manually
http://dl2.acronis.com/u/kb/VirtualDiskSetup.msi
i think the latest version is from 2014
There are only few informations in internet about this tool.
The program opens the space above 2TB as additional "2TB" virtual disk.
You see this in "Computermanagment". They are "primary" !!
In Explorer you see the full capacity of all your partitions.
I have tested sucessfully with Seagate 4 TB SATA
ST4000DM004 > 4K physical emulated at 512-byte sectors
Barracuda SATA Product Manual 100805918, Rev. P December 2020
You DONT need Seagate Extended Capacity Manager.
Another person tested with a WD30EZRX 3 TB WD Caviar Green
https://windowsforum.com/threads/hd-disk-mana … 40/#post-646781
Interface SATA 6 Gb/s
Advanced Format (AF) Yes
So it should work with disks from all manufacturers.
I have tested on a "old" MSI Board without UEFI.
I have tested with XP SP3 32bit , W2k3 64bit and Win11 23h2 64bit
(yes ! - win11 works with MBR - without UEFI !)
I have not tested with SSD.
I make a full capacity test with h2testw_1.4 without errors
4 TB write and test takes about 13 hours !!
It would interesting for me if the tool works with capacity more than 4 TB.
Maybe someone can test it.
But in "future" XP-users have another problem if
the disk provides no more 512e emulation
http://wp.xin.at/archives/2581
and if there are no more actual browsers
Greetings : LarryM from germany
