Reply 49680 of 57924, by mkarcher
ubiq wrote on 2023-06-29, 20:23:A riser card that provides 2 x PCI slots and 1 x ISA slot yet doesn't use a custom edge connector. I find it odd the lengths this thing goes to provide three slots and then only have two of them usable at once.
This adapter seems to be made to use mass-market standard boards (like your BF6) in slim desktop cases (that aren't high enough to provide space for 3 slots). The PCI-or-ISA position is for increased flexibility, just as they have a shared PCI/ISA slot on many PCI boards, too.
ubiq wrote on 2023-06-29, 20:23:It's got this wee little PCI adapter, I'm assuming only these 7 pins on the PCI bus are addressed:
If you mean "only these 7 pins on the PCI bus aren't just connected between on all slots", that's exactly how it works. The 7 per-slot pins are the four interrupt pins (INTA, INTB, INTC, INTD); two busmastering pins (REQ, GNT), and the configuration cycle slot select pin (IDSEL).
ubiq wrote on 2023-06-29, 20:23:Here's what it looks like on a BF6 with some cards stuffed in it:
Obviously this isn't the use case... 😂
Well, I think this is close to the intended use case, but likely not for an AGP-equipped board, and definitely not with non-low-profile cards plugged into the board at the same time.
