ATi RagePro OpenGL files
Reply 20 of 161, by Takedasun
marxveix wrote on 2022-04-30, 19:21:
I would like to get Rage OpenGL ICD 1073, it should have multitexturing support in it. OpenGL ICD name atoglrp9.dll (before 5.40), atio9xad.dll (5.40) or atio9xae.dll (J5.xx). 1073 should be before 5.40 releases, but i am not 100% sure, anybody has 1073 OpenGl ICD?
Talk about this 1073 and other RagePro OpenGL versions:
http://www.rage3d.com/board/showthread.php?t=1022
I found the damn file.
Reply 21 of 161, by Kahenraz
Where did you find it?
Reply 22 of 161, by Takedasun
GLSetup driver library
Reply 23 of 161, by dr.zeissler
This GL driver has an issue on my setup. Using this one leads to a corrupt screen when exiting a game that uses it.
Reply 24 of 161, by Takedasun
dr.zeissler wrote on 2023-04-19, 19:48:
I don't have that problem.
Test in Quake2
1068 - 23.6
1073 - 24.3
1076 - 23.1
1079 - 23.2
1085 - 23.1
Reply 25 of 161, by dr.zeissler
my machine is:
- 4MB ATI Rage Pro LT
- WIN95-DX6 (not 6.1)
- ATI 8247 DX5 Driver for ATI CIF compatibility
- Game: DoomGL (and others)
OpenGL is broken (textures) on that 8247 driver but the opengl from 19.01.1999 107x ? does work 100%.
Doc
Reply 26 of 161, by Kahenraz
Is there any particular reason you use DirectX 6 instead of 6.1?
Reply 27 of 161, by dr.zeissler
DX 6.1 has no benefits on that machine and there was a compatibility issue...but I can't remember yet.
Reply 28 of 161, by Kahenraz
I'm familiar with any compatibility issue. I would love to know my about this if you can find a reference for it.
Reply 29 of 161, by Kahenraz
Sometimes I wonder how useful some of these early 3D accelerators could have been if drivers for them had continued to be developed. I feel like the early Rage chips, for example, are a lot more capable than what we got with the final driver set.
Reply 30 of 161, by DrAnthony
Kahenraz wrote on 2023-04-21, 03:50:
Oh that happened all the time, even many years past that point. R100 had pixel shader capability that was never exposed by drivers. ATI engineers have gone on the record of saying it would never have met the eventual PS 1.1 requirements but if something had formalized sooner those cards would have done a lot more than we thought they were capable of. Honestly, I wouldn't be surprised if it was possible to write a DX8 compatible driver with pixel shader support, but it was just too slow on the hardware to be useful and definitely not worth the effort.
Reply 31 of 161, by dr.zeissler
R7000 runs r7500 Ark Demo with all shaders 😀
Reply 32 of 161, by marxveix
Takedasun wrote on 2023-04-19, 13:49:
Great news, Thank you Takedasun!
Now we also have version 4.11.1073 Win9x -OpenGL, probably i also get more performance, like you did in your quake2 results.
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
Reply 33 of 161, by Spark
marxveix wrote on 2021-03-19, 07:53:
Anybody have used 110x OpenGL-s for glquake, i get timedemo demo1 30fps with my k6-2+@350Mhz, but screen has flickering with them, any fix would be nice.
Open the console and type gl_ztrick 0 to fix the flickering.
Got this tip from the Scitech GLDirect docs. They mention glquake's ztrick can't be translated into Direct3D.
Perhaps ATI's latest ICD is wrapping some functionality to Direct3D which is why it needs this setting.
Also make sure to use glquake 0.97 as earlier version has severe performance issue when the console is open.
Another thing to look out for is that fraps takes a lot of performance away and causes textures to be improperly filtered.
Reply 34 of 161, by marxveix
Spark wrote on 2023-07-07, 21:45:
Open the console and type gl_ztrick 0 to fix the flickering. Got this tip from the Scitech GLDirect docs. They mention glquake' […]
Thank you Spark, this fixed it!
GLQuake fix > from OpenGL 4.12.1095 up to 4.12.1107 add
gl_ztrick "0" to quake/id1 autoexec.cfg or open glquake
console and type gl_strick 0 to fix missing bottom hud
(status bar) and screen flickerings before your gaming.
Edited autoexec.cfg works also with older OGL versions.
Win-win situation, just edit the autoexec.cfg if needed.
Edit:
Thank you Takedasun! - Great collection of drivers you have and it has been growing from the last visit i did, even with added D3D,OpenGL info for some driver file.
Now i have these new ones, added MiniGL/OpenGL i did found from Takedasun site.
(MiniGL 4.10.1005, OpenGL 4.10.1045, 4.11.1049, 4.11.1073, 4.11.1079 and 4.12.1100).
Full list at the moment:
MiniGL (Opengl32.dll)
4.10.1005 Beta1
4.10.1010 Beta2
4.10.1021 Beta3
4.10.1036
OpenGL (Atoglrp9.dl_)
4.10.1045
4.11.1049
4.11.1051
4.11.1058
4.11.1060
4.11.1065
4.11.1068
4.11.1073
4.11.1076
4.11.1077
4.11.1079
4.11.1084
4.11.1085
4.11.1091
4.12.1091
4.11.1094
4.12.1094
4.12.1095
4.12.1096
4.12.1100
4.12.1103
4.12.1104
4.12.1106
4.12.1107
Reply 35 of 161, by Takedasun
I have looked through the contents of the atoglrp9.dll file and found several values that can be used to enable SGIS_multitexture and ARB_multitexture support. To do this, you need to create a file called atidbg.ini in the C:\windows\ directory and write the following values into it:
[OPENGL]
EnableMTSGI=1
EnableMTARB=1
This method works for all versions of OpenGL (Atoglrp9.dl_) except the earliest ones.
[Kelvin]
Bilinear=0
Controls bilinear filtering of textures.
It seems that Ati RagePRO drivers ignore registry settings and the settings can only be controlled via ini files.
The attachment вопрос 3.png is no longer available
The attachment q2.png is no longer available
Reply 36 of 161, by Joseph_Joestar
Takedasun wrote on 2023-07-12, 11:07:
Interesting. Is there a setting which can enable GL_EXT_shared_texture_palette as well?
I'm asking because the Rage Pro and XL cards do support paletted textures in Direct3D games, with period correct drivers. Not sure why this isn't available under OpenGL though.
My retro builds
Reply 37 of 161, by marxveix
I have looked through the contents of the atoglrp9.dll file and found several values that can be used to enable SGIS_multitextur […]
[OPENGL]
EnableMTSGI=1
EnableMTARB=1
[Kelvin]
Bilinear=0
Great info there, Thanks!
Rage3 cards OpenGL bilinear filtering can be turned on and off with Rage Pro tweaker also ,
even after uninstalling tweaker software, settings stays the same, if you turned it off before.
edit:
After Kelvin setting i have i also these settings there, probably Rage Pro tweaker leftovers:
[Performance]
UseAsm=1
UseGen=1
BMPad=1
Reply 38 of 161, by Spark
Is there any point in enabling multitexturing in the driver when the Rage Pro can't multitexture? (to the best of my knowledge)
I enabled it and nothing seemed different in Quake 2.
Reply 39 of 161, by marxveix
Spark wrote on 2023-07-12, 23:40:
I got new OpenGL, version 4.12.1088
Multitexture works, just tested with my K6-2+ 400Mhz and Rage XL AGP 8MB (no overlock, no quake2 tweaks).
Quake2 OpenGL 4.12.1088
timedemo 1 map demo1.dm2
25.7 multitexture disabled
27.3 multitexture enabled (good graphics, good performance)
28.9 multitexture enabled, no bilinear
30.9 multitexture disabled, no bilinear (no bilinear filtering, best performance)
Multitexture should be enabled only if you use bilinear filtering for OpenGL.
Multitexture an bilinear enabled
[OPENGL]
EnableMTSGI=1
EnableMTARB=1
[Kelvin]
Bilinear=1
Multitexture and bilinear disabled
[OPENGL]
EnableMTSGI=0
EnableMTARB=0
[Kelvin]
Bilinear=0
I also had these settings
[Performance]
UseAsm=1
UseGen=1
BMPad=1
