First post, by AlessandroB
Today, checking my cpu collection, I found Pentium MMX in ceramic version. What is the difference between the ceramic and the plastic version? Do they have the same core and production process? L1 Cache? The only information I found is that the 233Mhz model is exclusive to the plastic version while at 166 and 200 there are both. Could it be for the greater dissipative surface to prefer the ceramic version ???
Reply 2 of 31, by derSammler
The ceramic version gets hotter, that's why it is enclosed in ceramic. The plastic version was optimized in production and produces less heat. Technically, they are identical in specs.
Reply 3 of 31, by Anonymous Coward
I think the first intel x86 CPU to use the plastic version was the P200 sans MMX. It got too hot for the ceramic packaging. When Intel started making the MMX chips, they used split rail voltages with reduced core voltage, which in turn reduced heat dissipation allowing the P166MMX and P200MMX to go back to the older ceramic package...perhaps until they used up whatever supply they had lying around.
Reply 4 of 31, by alvaro84
There's both ceramic and PPGA version of quite a few P5 models: classic 166/200, MMX 166/200 (desktop models). The insides are the same, I presume. The metal heat spreader should be better at transferring the core's heat to the cooler. Btw I have both kinds of 166-sans-MMX and both are stable at 200MHz.
AFAIK, the MMX-233 doesn't have a ceramic version, though, while the old classics below 166MHz are always ceramic.
Shame on us, doomed from the start
May God have mercy on our dirty little hearts
Reply 5 of 31, by AlessandroB
I asked this because I have a card with the 233mmx with the heatsink glued on and produce a very annoying noise. Unfortunately I can't install another CPU in plastic because the socket is not ZIFF and therefore it does not have hooks to block the heat sinks. I have to choose the heatsinks that hook directly to the CPU, and from what I know exist only for ceramic CPUs. That's why I wanted to use the Pentium MMX ceramic instead of the plastic version. Even if the ceramic version I own is only 200mhz I don't think it's too slower than the 233mhz plastic version. I forgot to tell that my board is a ss7 and bus can run at 100mhz, i can run my cpu at 100x2=200mhz. I think is really fast that the regular 233mmx (that can run at 100x2.5)...
Reply 6 of 31, by alvaro84
AlessandroB wrote:
...the regular 233mmx (that can run at 100x2.5)...
With some luck even the 200 can do the same. (Though the ceramic ones are usually from earlier batches so you have worse chances than with newer plastic ones).
Reply 7 of 31, by H3nrik V!
According to my own homemade Excel sheet, there is no ceramic 200 Classic. Was I wrong when making it?
Reply 8 of 31, by The Serpent Rider
Most likely not. Ceramic P200 were relabeled P166: https://www.cpu-galaxy.at/Article/fakes.htm
Reply 9 of 31, by H3nrik V!
Very interesting 😀
Reply 10 of 31, by AlessandroB
As i remember 200 classic is ceramic, then, when the 166mmx plastic come out, intel start to mix plastic and ceramic ,but 200 ceramic was made for sure.
Reply 11 of 31, by Anonymous Coward
Try to find one that isn't fake. I gave it my best shot but came up empty handed.
Reply 12 of 31, by alvaro84
I thought there was a very normal ceramic 80502200. So it was a fake...?
WANT 🤣
Reply 13 of 31, by Los Pebos
Hello,
I’m new here but loving hardware since decades. I’m taking the liberty of digging up this topic as I came accross what’s seems to be a Pentium 233 MMX in a CPGA package (ceramic, then, not plastic PPGA) but its sSpec is SL27S which relates to a classical PPGA P233 MMX. Also, I don’t find any mention of any CPGA P233 MMX anywhere else.
I haven’t tried to scratch it to see if it could be a relabelled P200 MMX (or even a P166 MMX) but the engraved numbers and printed labels seem pretty legit so far. What do you think? I also enclose the bottom of the chip, which printed stuff looks rather faded out.
Thanks for your advice on this!
    635.38 KiB
    373.36 KiB
Reply 14 of 31, by Sphere478
Oh that is interesting
I also have a curiosity, a 200mhz sl27s ppga
Sphere's PCB projects.
Reply 15 of 31, by Los Pebos
Sphere478 wrote on 2023-07-09, 08:34:
So same sSpec ID but different speed. I tend to think that the SL27S speed is 233 MHz, as per the various websites referencing it. Is yours labelled as 200 MHz or is running at 200 MHz (and could run faster)?
Reply 16 of 31, by Sphere478
Los Pebos wrote on 2023-07-09, 10:26:
labeled, I should check to see if it has the 3.5 X option enabled I suspected it probably does, though maybe not.
Reply 17 of 31, by gerwin
Los Pebos wrote on 2023-07-09, 08:12:
For one the front-side dark engraved copyright symbol is odd. The ends of the letter "c" in the circle do not meet close enough.
Fortunately, Asian counterfeiters tend to lack feeling for latin typography details.
Reply 18 of 31, by Sphere478
The marks on a ceramic are laser, if you look at it under a micro scope it becomes obvious very fast if it is melted ceramic or paint
Reply 19 of 31, by pentiumspeed
Fake. The way the laser burnt looks wrong and the copyright symbol is too comical.
Give it a scrape with sharp knife, the top layer should come off. I have a remarked Pentium 150 as 166 like this.
Cheers,
Great Northern aka Canada.
