First post, by fractal5
I have Quake 1.08 installed on Windows 98.
Regardless of running quake.exe or q95.bat I experience stuttering now and then. This isn't usual lag, but more that the game suddenly skips a few frames. This appears to happen arbitrarily and suddenly without any consistent pattern.
Note, I get high FPS, I can run 800x600 in software rendering without lag in terms of FPS.
Reply 1 of 11, by Joseph_Joestar
Try enabling V-Sync by editing Quake's config.cfg file and ensuring that the following two lines are present:
vid_wait "1"
_vid_wait_override "1"
BTW, that underscore symbol in front of the second line isn't a typo, it's supposed to be there. The DOS version of Quake sometimes exhibits screen tearing and other graphical glitches on fast systems. Enabling V-Sync limits the maximum FPS to your monitor's refresh rate, which might help with this problem.
My retro stuff
Reply 2 of 11, by fractal5
Joseph_Joestar wrote on 2023-07-09, 17:29:
Try enabling V-Sync by editing Quake's config.cfg file and ensuring that the following two lines are present: […]
vid_wait "1"
Excellent advice. Unfortunately, it didn't work.
Reply 4 of 11, by Gmlb256
Try QIP Quake, it has improvements, and the DOS version is faithful to the original one. Should work with the data files from version 1.08.
Reply 5 of 11, by leileilol
winquake with the -dibonly parameter should be enough (assuming video hardware is new enoughfor needing to dodge scitech mgl)
Debian's fucked
Reply 6 of 11, by Joseph_Joestar
fractal5 wrote on 2023-07-09, 22:24:
Interesting. I remember having similar (but not exactly the same) visual glitches on my AthlonXP system, and those settings resolved them for me. Not sure if it will make any difference, but try using this instead:
vid_wait "2"
It uses a slightly different syncing method. Oh and, if anyone's curious, a detailed list of Quake console commands is available here. That page also has notes on what each command does and sometimes even mentions in which patch version a particular command was introduced.
My retro stuff
Reply 7 of 11, by fractal5
Gmlb256 wrote on 2023-07-09, 22:40:
The DOS version runs, the visual stutter is gone, but now the audio stutters!
The WIN version doesn't run: It requires WDIRXX.DLL, I got this by downloading WDIR--DLL.ZIP
Got past that, however, now it needs:
pmproxxf.dll
Which I unfortunately cannot find.
Reply 8 of 11, by fractal5
Joseph_Joestar wrote on 2023-07-10, 03:50:
Interesting. I remember having similar (but not exactly the same) visual glitches on my AthlonXP system, and those settings reso […]
vid_wait "2"
Tried it, same.
Reply 9 of 11, by fractal5
leileilol wrote on 2023-07-10, 00:12:
I don't have the "winquake" executable, am I supposed to have that?
Reply 10 of 11, by Gmlb256
fractal5 wrote on 2023-07-10, 23:31:
Try adding this into CONFIG.CFG (the underline must be included):
_snd_mixahead "0.2"
This would ensure that enough samples are mixed ahead of the time.
fractal5 wrote on 2023-07-10, 23:32:
Can be obtained here: https://www.doomworld.com/idgames/idstuff/quake/wq100
It does include the necessary DLL files that you mentioned.
Reply 11 of 11, by fractal5
Gmlb256 wrote on 2023-07-10, 23:58:
Try adding this into CONFIG.CFG (the underline must be included): […]
_snd_mixahead "0.2"
Nice!
The qip_winquake.exe works as it should.
Tried the regular qip_quake.exe with:
_snd_mixahead "0.2"
and
_snd_mixahead "0.5"
Didn't change anything. Note, I had to make the config file read-only to even be able to test this, otherwise it seems Quake immediately overwrites it with other values.
