Reply 40 of 47, by smtkr
shevalier wrote on 2023-07-09, 12:04:My previous CUBX-L ran 1 GB of RAM at 133 MHz. Which is now - not, moreover, the memory is the same. Only 124MHz. Why play prob […]
Why play probabilities when ABit AB-BX6 2.0 already has soldered buffers?
My BX6r2 can't run 133MHz FSB, even if I just stick one stick of RAM in it. I recapped it and it didn't make a difference. I have a theory that it needs to have a hardware mod to bump vio, but I'm not going to mess with it.
One thing everyone needs to be aware of with this board is the location of the ATX connector which is the absolute worst. You'll have a power cable right in front of your rear case fan. If you want to use a modern PSU, forget about it because the extra pins will block your AGP slot. Also, one of the 3-pin fan connectors is right up against the power connector. I can't express in words just how bad the location of that connector is.
