Quake 1 bots
First post, by fractal5
This topic maybe doesn't quite fit here, as it is more about a recommendation than something that's outright broken, forgive me.
What is the best bot for Quake? Obviously this is an opinionated matter, I'm just curious if there's anything better than the Omicron bot.
I remember the Reaper bot was quite the breakthrough when it came out, but it had many flaws, such as, the bots were glued to the floor, you couldn't launch them into the air with rockets by shooting at their feet like you could with a normal human player in deathmatch. I remember this got fixed (probably before that) with the Omicron (?) bot, which was also superior in other areas.
But no bot I've tried could consistently do things like bunny jumping, rocket jumping, or employ highly skilled deathmatch play in general.
Just curious if this gap between good human players and bots ever got bridged beyond the Omicron bot.
Basically, if you want to play Quake (1996) against bots in deathmatch, what is a good recommendation?
Reply 1 of 10, by TrashPanda
Been a while but reaper bots come to mind, dude who made them went on to make the bots for Unreal Tournament.
IIRC there is also a version for Quake II as well.
Reply 2 of 10, by fractal5
TrashPanda wrote on 2023-07-12, 15:22:
Yeah as I mentioned, the Reaper bot was a breakthrough, and Steven Polge went indeed on to write the bots for UT as well. The Reaper bot is actually quite early in the overall history and development of Quake bots, though. So it is definitely not the best or even a good one, compared to more modern bots (like Omicron).
Reply 3 of 10, by fourier
To play with bots you better to install modern multiplayer quakeworld client from http://nquake.com, it even supports old-school graphics. Then follow the guide https://www.quakeworld.nu/wiki/Playing_with_bots
QuakeWorld still has a pretty active (even small) community, you can find all the information on a wiki (start with https://www.quakeworld.nu/wiki/Qwrookie), there is even a discord server for it: discord.quake.world iirc
Good luck!
Reply 4 of 10, by Kerr Avon
Doesn't the recent-ish Quake remaster have bots? How do they compare to the third party bots?
The thing I didn't like about the Quake third party bots was that there was no in-game menu for adding/removing/modifying bots and their behaviour. It wasn't a total loss, as you could bind the bot options and commands to your your choice of keys, but it was a little disappointing. A flaw it shared with every third party bot I can think of for every FPS that didn't have native bot support.
Reply 5 of 10, by fractal5
Kerr Avon wrote on 2023-07-12, 23:25:
I think it isn't that bad with later bots, the original Reaper bot uses "impulse 205" or something like that to spawn a bot, while later bots like the Omicron just uses "addbot". It isn't a big deal I think to just have to type that in the console a few times.
On the other hand, the pain of getting Quake to work at all, isn't trivial. I've had issues with the graphics stuttering, with the sound stuttering, and now with CD audio.
Quake also has a weird configuration system for its config files, I had to create a new config instead of writing to the original config file (and use autoexec to start my new config), otherwise it seems to overwrite my changes to the original config file.
Reply 6 of 10, by Errius
Man I haven't heard about Reaper bots in a long time. I remember playing them when I was on dial-up and could only be on the internet at certain times of the day.
I still have my old Quake installation:
"This all reminds me when i took the windows vista sticker thingy off my old laptop, and on my washing machine as a joke. A few days later said washing machine stopped working. I still think this cannot be a coincidence."
Reply 7 of 10, by TrashPanda
fractal5 wrote on 2023-07-13, 16:37:
I think it isn't that bad with later bots, the original Reaper bot uses "impulse 205" or something like that to spawn a bot, whi […]
Just set your original config to read only, should stop any unwanted alterations 🤣
Reply 8 of 10, by Errius
There were Frogbots and Gyrobots too. And even a QWTF bot that never got completed IIRC (only a few classes were operational)
Reply 9 of 10, by fractal5
Errius wrote on 2023-07-13, 18:08:
1996 timestamp on some of those files, wow!
I envy you for having correct timestamps from way back then, my timestamps have been mangled multiple times from migrating between filesystems (fat32, to linux with ext2, ext3, ext4, to windows again with ntfs, etc. etc.).
Reply 10 of 10, by Errius
It's actually a fresh installation of Windows (hence the directory with a July 8 date). My drive (a crappy WD Green SSD) failed on Friday and I had to spend the weekend reinstalling everything and restoring backups.
