478 vs 775 insurrection
Reply 80 of 90, by ediflorianUS
2mg wrote on 2023-07-09, 20:14:
Slight necro, but can someone ELI5 how did pre-C2D Intels with 2 "cpus glued together" actually handle FSB?
Did they share it, aka could one "core"choke the other, or was is 1/2 FSB speed split per "core"?
they where not glued together , 1 PCB , 2 dies (worked like dual Xeon 604)
?u=https%3A%2F%2Ftse1.mm.bing.net%2Fth%3Fid%3DOIP.ALbCoJO_oZymlkY3bekfZgHaDi%26pid%3DApi&f=1&ipt=021d88c86a2eaf8e25fb3635c43b47e6a6b979bf7c1057c759ddd5514ee428bc&ipo=images
https://cpumuseum.jimdofree.com/museum/intel/pentium-d/
https://www.bit-tech.net/reviews/tech/cpus/in … 4_670_pd_820/1/
and BTW , under early winXP versions , early vista and even some early 32 bit win7 , in day to day bassis Pentium D series , based on Netburst would handle better than C2D , not to mention posiblity of HT.
My 80486-S i66 Project
Reply 81 of 90, by 2mg
ediflorianUS wrote on 2023-07-11, 10:21:
Thanks.
By early, do you mean "before they got Service Packs and better support" or "early programs didn't run as good per se"?
Reply 82 of 90, by The Serpent Rider
90nm Pentium D were actually glued together. Your second picture is a die shot of the Smithfield core. It also has additional data bus to poke neighbors L2 cache.
Reply 83 of 90, by 2mg
The Serpent Rider wrote on 2023-07-13, 01:16:
I'm still a bit confused how'd these use the shared FSB, but that explanation might be a bit too technical.
Reply 84 of 90, by The Serpent Rider
Mostly as a classical dual socket system, as mentioned before.
Reply 85 of 90, by TrashPanda
Intel bodge job CPUs, ran so hot you could cook steak on them!
Fun times for weak VRMs too.
Reply 86 of 90, by ediflorianUS
2mg wrote on 2023-07-12, 23:06:
Thanks.
before service packs , sometimes even after. PreVista (longohorn editions or beta + SP1)
"Intel bodge job CPUs, ran so hot you could cook steak on them!
Fun times for weak VRMs too." - nonsense TrashPanda , it was even worse with the early lga P4 3.6+ Ghz editions
I had no issues with any D series on Dell cooling. (for 15+ years now)
Reply 87 of 90, by TrashPanda
ediflorianUS wrote on 2023-07-14, 12:25:
before service packs , sometimes even after. PreVista (longohorn editions or beta + SP1) […]
Thanks.
You could indeed cook steak on them .. even seen videos of it being done, and weak VRMs did have issues with the Pentium D CPUs. Just because you have had one good experience with one doesn't mean the large body of evidence contrary to your experience is wrong.
Spent way too many hours repairing machines to just take one or even a handful of good experiences as fact. I will admit that in general Dell did have decent cooling in their business machines but they learned from their prior mistakes so their cooling was also generally overkill.
Pentium D was shite - change my mind ..wait dont bother you cant. (Conroe Pentium already did that)
Reply 88 of 90, by 2mg
TrashPanda wrote on 2023-07-14, 12:47:
Would a modern cooler ala Scythe Mugen 1/2 s478 handle these monsters?
And maybe some ghetto small coolers and/or small heatsinks to chill VRMs on mobos too?
Reply 89 of 90, by GokuSS4
Bancho wrote on 2023-02-14, 20:01:
Along with my Soyo P4 ISA build I posted earlier in the thread I do have this Asus 775 e5200 build with a ATI x850 XT PE which […]
Along with my Soyo P4 ISA build I posted earlier in the thread I do have this Asus 775 e5200 build with a ATI x850 XT PE which I run WIN98SE on. Not installed XP on it yet mind.
Which case is that?
Win10 Ryzen 7 5800X | TUF B450M-Pro | 32GB DDR4-3800 CL16 | RX 6800 XT
WinXP Core i3-3220 | H77 Pro4-M | 8GB DDR3-1600 CL9 | X1950 Pro
Win98SE Pentium E5800 | 775i65G R3.0 | 512MB DDR1-400 CL2 | X850 XT
Reply 90 of 90, by PcBytes
As much as I dipped my toes in 775+AGP territory with several boards (775i65G R2.03, P5P800, P5PE-VM, 775i65PE R1.03), my vote goes to 478, specifically the 845 series.
They were the middle ground of the Pentium 4, more or less. Prescott wasn't yet a thing, Northwood runs cool enough, you get 333FSB support, and SATA wasn't much of a standard (most I've seen to offer SATA were thru 3rd party controllers, such as Promise Fasttrak series, Highpoint and Silicon Image), making it widely compatible with 98SE in native terms.
Also SB-Link, if you're lucky enough.
