Reply 20 of 34, by GigAHerZ
- Oldbie
smullyoz wrote on 2023-06-12, 14:11:Problem is the slot for the fan power on the card is that little three pin thing. The ones from your photo won't work.
When googling the fan part # i found a fan replacement but that's $40 with shipping and ill still have to use the original heatsink which is pretty crappy.Any other video cards besides the GTS use that 3 pin power?
The third pin is unnecessary. If you really want, you can even take the power from molex connector. 😁
