First post, by alphaharris
- Newbie
Hi all (: This is the first CD-ROM I had access to as a kid, so it'd be pretty cool to get one working on my Compaq 386.
The Problem:
Detected by SCSI ASPI install, but not detected by CD-ROM driver on Boot
"Device driver not found: 'ASPICD0'No valid CDROM device drivers present
Similar to SCSI CDROM DOS Drivers [?] but different drive and adapter
Wayback machine: https://web.archive.org/web/19961110142952/ht … rt/allparts.htm (Fusion CD Kit, not Fusion 16)
Not sure if it was sold with a PAS or with some other SCSI adapter. I haven't figured out "which" PAS-- that might be a solution.
Best Guesses:
- Special host adapter (NEC?), cord, or terminator needed
- Something wrong/missing in autoexec.bat or config.sys
- PSU issues causing intermittent power
What I've tried:
- I have an Adaptec SCSI host adapter ADAPTEC AHA-1510A (Both CD-rom and adapter are 50 pin Centronics) It includes a CD-ROM driver.
- Opened it up to look for a terminator jumper or slot.. didn't see one
- There are switches on the bottom, but they just change address. I have tried several. On similar models one activates an internal terminator, but this one doesn't say that.
- Changing the host adapter ID and jumper positions
- EZSCSI (not sure how I landed on this) seems to install fine, detects the CD-ROM as an NEC CD-ROM (Correct), and modifies the Autoexec and Config.sys automatically
- ASPI seems to install fine at Boot and load host adapter
Notes:
- I don't know much about SCSI termination. The adapter is terminated. The CD-ROM doesn't have anything recognizable as a terminator or socket.
- I don't know much about the DEVICE line in these startup files or how that's supposed to work. I could use an explanation (:
- There is some light but noticeable corrosion on the CD-ROM board. I don't have a schematic to test voltages.
- Sometimes during SCSI install it freezes when it gets to the CD-ROM device ID (currently 6).
- The CD-ROM wants 10 volts DC and its plugged into a 9 volt DC adapter, since I don't have 10 handy.. if that's dumb I have a 10v in the mail and several 12V adapters
- There is a list of drivers mentioning PANASCSI on a shady driver site that tries to download spam. But is this a clue?
Thanks a million for any help. Please let me know if this is the wrong area of the forum. I'll try to respond in a timely way. Just interested in getting it working as a CD-ROM drive.
