First post, by brian.t
I have a Jamicon KMC-40A motherboard. I recapped the mobo, removed the onboard battery, and replaced it with an external 3.6V Tadiran TL-5242. Motherboard seemed to hold CMOS settings for a couple months now (although the clock may have been running a bit slow). Now the computer can't keep bios settings after a power cycle. I measured the voltage at the RTC Vdd pin and it's about 0.4V with power off, but the external battery is 3.63V. Just wondering if I may have selected the wrong battery. The attached photo shows the battery connection, the diodes on the mobo, and the RTC. Thanks!
