Socket A: Nvidia vs Via - battle of the platforms!
Reply 260 of 1179, by nd22
KT600 is again defeated by its newer brother but this is not a huge problem; the problem is the fact it is also defeated by nforce2 which is a bigger problem for VIA:
nforce2: 14351 - 100%
KT880: 13749 - 95.80%
KT600: 13392 - 93.31%
Reply 261 of 1179, by nd22
We have reached the final and most challenging test done at 1600*1200:
Reply 262 of 1179, by nd22
The results at this extreme settings are too close to declare a victory for any of the 3 chipsets:
nforce2: 12563 - 100%
KT880: 12240 - 97.42%
KT600: 12414 - 98.81%
Despite the fact that the results at 1600*1200 are not conclusive, I think that based on the results at 1280*1024 and 1024*768 nforce2 has established itself as the victor in 3dmark 2001!
Reply 263 of 1179, by Am386DX-40
Impressed by the KT600. Looks to be better than the KT880 which souds counter-intuitive. Was the KT880 another VIA flop like the KT400 and KT266?
Reply 264 of 1179, by nd22
I do not think that KT600 is better than KT880! 1-2% better in tests is within the margin of error IMHO. You will see later that there is a problem with KT600, but let's not anticipate for now! Audio wise VT1616 codec is miles ahead of ALC650 and that is a big difference in all tests that include sound!
Reply 265 of 1179, by nd22
We are now going to test 3dmark 2003, a DirectX9 benchmark.
First is 1024*768 resolution!
Reply 266 of 1179, by nd22
KT600 stands up pretty good:
nforce2: 11523 - 100%
KT880: 11345 - 98.45%
KT600: 11211 - 97.29
Too close to declare a winner!
Reply 267 of 1179, by nd22
Going up to 1280*1024:
Reply 268 of 1179, by nd22
Again the scores between all 3 chipsets are too close to call!
nforce2: 5373 - 100%
KT880: 5343 - 99.44%
KT600: 5335 - 99.29%
Reply 269 of 1179, by nd22
And finally the big daddy: 1600*1200 resolution!
Reply 270 of 1179, by nd22
Again the results are incredibly close!
nforce2: 4154 - 100%
KT880: 4189 - 100.84%
KT600: 4225 - 101.70%
3dmark 2003 does not have a winner! All 3 platforms perform really close and geforce 7800gs is already starting to be the limiting factor beyond 1024*768!
Reply 271 of 1179, by nd22
We have now reached the final 3dmark: 2005! Heavily dependent on the video card, let's see if the KT600 can make up for earlier losses!
1024*768 default settings:
Reply 272 of 1179, by nd22
The results are pretty close; nforce2 has a very small advantage - within the margin of error:
nforce2: 5449 - 100%
KT880: 5376 - 98.66%
KT600: 5310 - 97.44%
Reply 273 of 1179, by nd22
We increase the resolution to 1280*1024:
Reply 274 of 1179, by nd22
The scores are even closer, the video card is strongly limiting performance!
nforce2: 3628 - 100%
KT880: 3639 - 100.30%
KT600: 3647 - 100.52%
Reply 275 of 1179, by nd22
And the final 3dmark 2005 test, at 1600*1200:
Reply 276 of 1179, by nd22
By now it is clear that 3dmark 2005 is too much for geforce 7800gs; that raises the question: how could Tom and Anand declare geforce 6800 ultra or radeon X850 XT PE as "extreme gamers cards" that "offers smoother playability" to their owners in Battlefield 2, Quake 4 and so on if a stronger card has serious problems in previous year games such as Doom 3 and Half life 2 at max settings and also in synthetic benchmarks!
nforce2: 2977 - 100%
KT880: 2974 - 99.89%
KT600: 2986 - 100.30
Reply 277 of 1179, by nd22
We are finished with 3dmark and now we test PC Mark version 2002:
Reply 278 of 1179, by nd22
We are not interested in the overall score but in individuals scores:
CPU scores are extremely close:
nforce2: 6402 - 100%
KT880: 6345 - 99.10%
KT600: 6413 - 100.17%
RAM
nforce2: 6264 - 100%
KT880: 5883 - 93.91%
KT600: 5064 - 80.84%
The superior memory controller of the nforce2 makes a difference here and enables Nvidia to score a victory in the memory test; also the dual channel controller in KT880 makes the KT600 memory score looks anemic!
HDD score is not taken into account as I switched to WD 150gb on all socket 462 systems with a SATA controller last year and tests on AN7 & KW7 were done in 2021!
Reply 279 of 1179, by nd22
PC mark 2004 is next:
