Create better compression?
First post, by Harry Potter
Hi! I am working hard on better compression techniques. So far, some Commodore 64 versions do much better than their Windows counterparts, and I don't know why. 🙁 Worse yet, the C64 versions pass a realism test, while the Windows ones don't. I might need some help with that issue. If I succeed, is there a calling for a much better compression technique? One that can well exceed 7Zip even on an 8-bit computer? So far, I'm getting that on 8-bit systems. If there is, whom can I serve? I need to compress a lot of floppies and Zip disks for myself on several different computers.
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 1 of 29, by megatron-uk
I think you will probably find that there isn't much call to use compressed floppy images or compressed files on floppies/zip/cd or similar these days.
Modern solid state drives really give retro computer users as much storage as they would ever need.
I can see the use for compression in an application or game where you may want to fit data in a given amount of runtime memory, but for storage? Not so much these days.
Storage is cheap for old computers... But processor time is something not as easily increased.
https://www.target-earth.net
Reply 2 of 29, by Harry Potter
So no go? 🙁 I see a lot of ZIP and 7Z files on the internet. A better compressor should work better there, no? At the very least, very large files could be 5-10% smaller. Would that be doable?
Reply 3 of 29, by megatron-uk
Why?
Storage is dirt cheap. Unless you are inventing your own compression libraries for fun, or use inside an application or game, it's really not bringing any benefit what so ever - is your intention to unzip / uncompress all the content you already have, and then re-compress using your own tool? What benefit will that give you? Yes, you may save a few bytes here and there for things that have to fit on a floppy disk... but are you *really* still using floppy disks to archive things?
Reply 4 of 29, by Disruptor
Wait, we're talking about a Commodore C64.
But what does neet to be compressed on the C64? Or is it just the decompression that matters on that little machine?
Reply 5 of 29, by BitWrangler
Well C64 to 1541 drive is almost like using another PC as a filesystem over serial laplink. i.e. it's not terribly fast, so if your data is compressed, it might give an apparent speed up when you're getting 30% more data for your data. There's a point where your storage is not slow enough relative to the speed of your CPU where the time to decompress exceeds the time saved in data transfer.
But anyhoo, zip is not the optimal archiver, it just has the network effect utility of being most common and popular. Others like RAR and ARJ have outperformed it in compression ratio. There are others that shave a few percent off those. Usually though you are choosing speed OR high compression.
Reply 6 of 29, by Harry Potter
Well, I need it for several PCs and a C64C and Plus4, as I use a lot of floppies and Zip disks on them. Also, earlier today, I found one of my flash drives to be almost full, so I kind of need better compression. 😀 I really also want to publish my techniques. 😀
Reply 7 of 29, by Babasha
Nice! I wait for a comparission and benchmark.
Need help? Begin with photo and model of your hardware 😉
Reply 8 of 29, by Harry Potter
Some of my compression techniques are doing extremely exceptional but others very poorly. 🙁 Right now, the C64 versions are doing much better than the PC versions, and I don't know why. Also, the C64 versions pass my realism tests, while the PC versions don't. Once I figure it out, I should be closer to debugging the PC versions. I thank you for your support! 😀
Reply 9 of 29, by root42
Can you elaborate a bit of what you did so far? Have you written your own compression algorithm? Are you using off the shelf tools?
Do you know there are competitions for most efficient algorithms, like this:
https://gdcc.tech/
Also, different algorithms perform different depending on the input. There is obviously also a hard limit of how much you can compress arbitrary data, depending on its entropy. Specific datasets might compress even better, but that really depends on the domain the data is coming from
YouTube and Bonus
Reply 10 of 29, by Harry Potter
Well...I'm working on my own compression techniques, and so far, some of my compression techniques are doing much better than 7Zip--even some of my 8-bit compression techniques. However, they are no where near usable yet--I have to start debugging them soon. BTW, I have an early PC version I just found, and it was doing much better than 7Zip on large files but much worse on others. I believe I deprecated it because of the latter. BTW, I'm also working on compression of individual strings using tokenization and RLE of spaces and applying compression of literals, but the Commodore community turned me down. 🙁
Reply 11 of 29, by Jo22
Harry Potter wrote on 2023-07-22, 23:40:
Don't let yourself be put down or discouraged by such people, they're simply like that.
I've noticed similar attitude here in Vogons in past years, too. People change, start a family, getting old..
They're simply nolonger are the cheerful and energetic people they used to be. They need a practical purpose to justify doing things, too.
Anyway, it's not their fault, either.
Reply 12 of 29, by root42
Do you have any code to share or try out? Would be interesting. What kind of compression are you applying? Anything akin to existing stuff? Entropy encoders, Huffmann, Lempel-Ziv whatever...? I only re-implemented a few existing ones a long time ago. But I find the topic quite interesting.
And what do you mean by "turned down"? How can they turn you down? If you simply release something for use on the C64 or so people can just pick it up to use. I mean that's how all the popular IRQ Loaders and packers are anyway.
YouTube and Bonus
Reply 13 of 29, by konc
So you are developing not just one but some compression techniques that are not just doing better but much better that 7zip? On real data?
Honestly I very much doubt this. I'll be very happy to be proved wrong though and salute a new Galileo 😉
Reply 14 of 29, by Harry Potter
Well, so far, it is, but I need to debug it. I thank all of you for your encouragement. 😀
Reply 15 of 29, by Harry Potter
Earlier today, I reached 5.6% better than 7Zip overall on my test files but was doing not quite so well on some small files. I am fixing that right now. Unfortunately, I lost the results--apparently, I didn't save the file that recorded them properly--and am retallying the results. Soon, I have to start optimizing and debugging. 😀
Reply 16 of 29, by jakethompson1
konc wrote on 2023-07-23, 08:54:
Especially since we are talking C64 here I wonder if it's a situation of 7z header overhead making the 7z files bigger
Reply 17 of 29, by Harry Potter
Well, the technique about which I'm talking here is actually a 16-bit technique, even though I'm using 32-bit code on a 64-bit computer. I'm sorry about the confusion. 🙁
Reply 18 of 29, by Harry Potter
Now, I'm doing much better on small files. I'm doing too good, but my realism test passed on them. The realism test involves trying to compress an uncompressible file, in this case a 1.5k .zip file. If it gives me a small loss, the technique might be real or about real. If it costs too much, the technique's probably inefficient. If it gives me even a slight compression ratio, there has to be a bug in the code. I want to give myself until the end of tomorrow to buy some more points here.
Reply 19 of 29, by megatron-uk
That's really not how you should be measuring effectiveness.
You take you source file and create a hash of it, using some standard tool like md5, sha or some other similar hashing algorithm.
You then compress the source file. Record the size.
Finally uncompress the compressed file.
Now run the hashing algorithm in the resulting file. If the two fingerprints are the same, then you have got the same out as you put in, and you know the compressIon (a) works, and (b) how effective it is.
