First post, by CoolDoomer
Good afternoon!
I found at one of my acquitance warehouse this motherboard and I am trying to make it work.
I put ram, pci video card, slot 1 pentium 2 processor and an atx power supply which I know it works with a socket 462 motherboard. I put the multiplier switch to the lowest amount.
When I power it on, the buzzer starts beeping continously, with no pause, for 2 -3 seconds the power led and the cpu fan work, but it shutdowns itself.
Does anybody know what countinous beeping means. Any help is appreciated.
Reply 1 of 14, by shevalier
CoolDoomer wrote on 2023-07-23, 12:49:
Good afternoon! I found at one of my acquitance warehouse this motherboard and I am trying to make it work. I put ram, pci video […]
Good afternoon!
IIRC, for Award Bios - continuous beep is "NO RAM".
Try extract all RAM stick and start the board. Must be same sound.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 2 of 14, by CoolDoomer
Now strangely it doesn't beep anymore and it still closes itself down. I suspect is something related to shorting or power issue. I inspected the motherboard and the capacitors seem to be fine. I noticed a scratch on the bottom of the board. Not sure if this is the cause?
The attachment _DSC4900.JPG is no longer available
https://imgur.com/a/lJcIXkq
Reply 3 of 14, by CoolDoomer
shevalier wrote on 2023-07-23, 13:49:
Good afternoon!
I tried. It doesnt change.
Reply 4 of 14, by CoolDoomer
The attachment _DSC4906.JPG is no longer available
The attachment _DSC4908.JPG is no longer available
Reply 5 of 14, by CoolDoomer
I tried putting an AGP card in there and I realized it is able to power it up because the fan of the card spins.
Reply 6 of 14, by shevalier
Obviously something leaked and then corroded.
I would unsolder a couple of capacitors and see what's under them.
A scratch on the back of the board - you need to check, alas.
Reply 7 of 14, by oh2ftu
What brand are those caps?
Reply 8 of 14, by Repo Man11
There are motherboards out there that won't POST if the CMOS battery is dead or not present, so be sure to check this if you haven't.
Reply 9 of 14, by shamino
CoolDoomer wrote on 2023-07-23, 18:58:
That just means the 12V rail is conducting into the slot. It's not a sign of very much.
There are also 5V and 3.3V rails going into the same slot, the fan doesn't confirm those, and we don't know if voltages are close to spec.
The beeping though does mean that the CPU is powering up and running. That's a sign of some life.
Do you have a multimeter? Try to find the other end of that trace and check for continuity across the scratch. It can be hard to get the probes to contact the pads so don't give up too quickly, you might have to push and twist a bit to get the probes into contact.
I don't have this board so I don't know if it would be normal for it to power off after a minor fault like "no RAM".
After it powers off, can you just switch it back on again, or do you have to reset the PSU by unplugging it first?
There is a "Power Good" signal involved with ATX and the voltage regulator on the board, but I don't know any details on how that whole scheme is designed to work.
I wonder if this could be a failure in that area - but I don't know if these are the correct symptoms (runs for a few seconds then turns off).
Depending what's wrong, it's possible this board is overvolting the CPU or maybe other hardware that's attached. Don't plug anything into it that you consider valuable.
I wonder why it stopped beeping - try reseating the CPU, slot-1 is flaky. Not to be too paranoid but if there's an issue with the Vcore regulator then there's also the possibility the CPU has died.
Reply 10 of 14, by CoolDoomer
shamino wrote on 2023-07-24, 22:08:
That just means the 12V rail is conducting into the slot. It's not a sign of very much. There are also 5V and 3.3V rails going […]
Sorry for the late reply. Thank you very much. I got today more time and put a diagnostic card.
The attachment 3-94329.jpeg is no longer available
When I powered it on it behaves like this.
https://imgur.com/a/iHALpRt
And it stops at C100. I think it uses here only 2 digits.
Reply 12 of 14, by CoolDoomer
Shponglefan wrote on 2023-08-22, 18:43:
C1 is is a memory detection / size check.
If it's not getting past that point, it sounds like a RAM related problem.
I put all Dimm modules and now it doesnt beep and it showed more messages. But it still closed off. I had to power off the PSU to repeat the test.
C100 -> 0CC1 -> C30C -> C5C3 -> 0503
My BIOS is AWARD PCI/PNP686
https://mrbios.com/techsupport/award/postcodes.htm
It seems at Late Award BIOS (4-5x PnP), it suggest 05 as being keyboard controller check. It seems that something is working.
https://imgur.com/a/aGcCyTq
Reply 13 of 14, by CoolDoomer
If somebody knows whats happening based of my video recordings, please let me know. Thanks.
Reply 14 of 14, by CoolDoomer
CoolDoomer wrote on 2023-08-22, 19:57:
I put all Dimm modules and now it doesnt beep and it showed more messages. But it still closed off. I had to power off the PSU t […]
What I find weird is that with one Dimm Module on the first DIMM Slot it buzzes and it makes that memory error on the Diagnostic card. Is this a sign that the first Dimm slot is problematic?
