First post, by egbertjan
I have an ASUS P5A-B rev 1.04 and have an AMD K6-2 500mhz processor on it The post says I have a 550MHZ on it. I have checked all jumpers and they are set for an AMD K6-2 500mhz. See the pictures below for my jumper settings. Who knows what's going wrong here
The attachment 20230729_143559.jpg is no longer available
The attachment procesor.jpg is no longer available
The attachment 20230729_143614.jpg is no longer available
The attachment 20230729_143621.jpg is no longer available
The attachment 20230729_143626.jpg is no longer available
Reply 1 of 5, by BitWrangler
Until a few years into this century, a motherboard could only tell the core generation of a CPU, not exact model and pretty much guesses the speed from timing loops at boot. So nothing much wrong per se, though it might be right-er with a later BIOS.
Reply 2 of 5, by egbertjan
the latest version of the bios is on it 1011.005
Reply 3 of 5, by dionb
That certainly looks like it's jumpered for 5.0x multiplier (BF0 to 1-2, BF1 and 2 to 2-3) and 100MHz FSB (FS0-2 on 1-2, FS3 on 2-3). You're also running the latest BIOS, so it's not a lack of K6-2 support on that side...
So, one of three options:
- BIOS isn't measuring correctly.
- BF1 is somehow shorting 1-2 instead of 2-3, leading to 5.5x multiplier.
- FS0, 1 and 3 are all doing opposite of how they are jumpered, leading to 110MHz FSB.
I'd suggest changing multiplier, then FSB and looking at what happens:
- change multiplier from 5.0x to 4.5x (move BF0 from 1-2 to 2-3) and see what BIOS says. If it still says 550MHz, it's not certain yet. If you get 400MHz, BF1 is somehow stuck on 1-2. If you get 495Mhz, you're somehow on 110MHz FSB or BIOS has a consistent measuring issue.
- with multiplier still on 4.5x, change FSB from 100MHz to 95MHz (move FS0 from 1-2 to 2-3) and see what BIOS says. If it *still* says 550MHz, BIOS is just messing around. If you get 380MHz, that's confirmed measurement is correct and BF1 is stuck on 1-2. If you get 427.5MHz, BIOS is measuring incorrrectly, but at least doing so consistently, and if you still get 495MHz, FSB is stuck on 110MHz somehow.
Reply 4 of 5, by BitWrangler
If the timing crystal and FSB reference crystal are two different crystals then one might be out of spec WRT to the other.
Reply 5 of 5, by Repo Man11
Have you checked with something like CPU-Z in Windows?
