First post, by silent-scream
Game Title is any, or all, of the following.
V for Victory : Battleset 1 : D-Day Utah beach - 1944 (PC V1.1)
I've tried to run under XP and through both VDMS & DOSBOX, all give the same message, "Sorry, no suitable installation drive is present ~ Press a key to exit" Install then aborts.
Never played this game before, got it in a sale a few weeks ago and don't even know if I'll like it.
It comes on a single floppy and was designed for an IBM PC with DOS 5 or higher and should run on a 286, 386 or 486. The disc contains 5 files, one of which is CHECKSYS.EXE that reports on machine & video setup. checksys.exe comes from Three-Sixty Pacific inc & is v1.1 (1992)
It seems to be trying to detect VESA cabability.
The other files are INSTALL.EXE, two read me files and the data file.
I've searched the net for the error message and I cannot find it
I've searched for the game and it's reprted as 'supported' under DOSBOX.
I've tried changing the machine type in DOSBOX.CONF using all the supported modes, VGA, CGA, HERCULES & TANDY
I've found a thread about a DOSBOX patch that specifies a chipset, ET4000, that's one of those which CHECKSYS is supposed to like, Emulation inside emulation: DOS-based emulators under DOSBox., but I cannot find any reference to a chipset parameter in the DOSBOX documentation
Tried on current pc which runs Xp
GFX card is a new GeForce 8800 Ultra
CPU is a quad core pentium
Tried on old pc which also runs XP
GFX card is a GeForce 6200
CPU is an ATHALON 1900
Sure I'm missing something obvious but I've been trying this for a week now and Ihave no idea where to look for the answer, anyone any suggestions?
Reply 1 of 4, by eL_PuSHeR
Did you try to manually copy all files/subdirs to a folder in your hardisk and checking what invokes this game (a batch file, perhaps)?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 4, by silent-scream
Thanks : Gonna sound like a typical user here but I know I tried this and it didn't work. Just repeated the process, copied the floppy to a folder and tried to run it with DOSBOX - no joy
Tried in native XP - no joy
Good News : Tried with VDMS and 'Viola!' the install process passes the 'no suitable installation disc check'.
Got message from VDMS about the applcation trying to access the root directory, chose to ignore and it's loaded.
Thanks for suggesting that I do the obvious, If you hadn't I'd have remained both mystified and convinced I'd already tried this.
So to get this game onto my pc I had to
- copy the floppy to the hdd
- run install with VDMS
- ignore VDMS dire warnings about accessing the root directory
- run the loaded game with DOSBOX.
Case closed
Reply 4 of 4, by silent-scream
Good advice
appreciated
Good night & Thanks again
