Reply 49960 of 59456, by gerry
shamino wrote on 2023-08-02, 06:43:<continued for 5 attachment limit> […]
TNT2 M64 "Pro"
This was listed as a TNT2 Pro, and the labeling implies that with the name "G4000 Pro", but it's actually an M64.
I think there's such a thing as an "M64 Pro" - an M64 that's clocked slightly higher on the core, and that's what this is, apparently. The Windows driver lists the device name as "TNT2 Model 64 / Model 64 Pro" so apparently the latter exists.
So I was disappointed with what this turned out to be, but it appears to be new or at least well kept. It's a late produced card with 32MB. It works fine and overclocks well and although there was a return policy I decided to keep it. Believe it or not, this is my only working TNT2 card, low end as it may be. I'd have been a lot happier with a proper TNT2 Pro, though.
It clocked up to about 184MHz core / 194MHz RAM, so it likes to run.
even such a modest tnt2 is still good for just about anything the late 90's can throw at it, good all round cards so its nice to have it in your collection as its the only one (working)
